Bilstein 5100/Toytec Coil Sag
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Blandino, Jun 25, 2017.
  1. Jun 25, 2017 at 1:37 PM
    Blandino
    Blandino [OP] Well-Known Member
    Damien
    2011 Double Cab Tacoma
    Whistle Tip Exhaust
    So I've had this Toytec Ultimate 3" lift with Camburg UCA's on my truck for about four months now with 285/75/16's. Originally I had plenty of clearance and my truck sat fairly level. Within the last month or so it's sagging to the point where the tire rubs the pinch weld and the cab mount when turning my wheels on level surfaces. I've added an AP Apex Aluminum bumper (55 lbs) and a Warn XPS 9.5 (78'ish I think). I plan on folding the pinch welds over and cutting the cab mounts in prep for AP's LT kit, but I'd like to raise the front since it will be another month before I close on my house and have a garage available.
    Is the addition of 135lbs to the front of the truck enough to cause this? Toytec warns that raising the clip above the 2nd position will cause damage, but I've read through numerous threads where folks claim you can raise the clip as long as you don't exceed 3", or to just add spacers. What are the dangers or raising the clip position to bring it back to 3" up front? Ideally I'd like a fix that I can do in a hotel parking lot without a lot of tools. It would be nice if I could just put a spring compressor on the coil and move the clip up so I'd just have to remove the wheel instead of the shock.
  2. Jun 25, 2017 at 4:10 PM
    captn.fat.beard
    captn.fat.beard Well-Known Member
    Anthony
    NJ & Philly PA
    13' DCSB on 33"
    not sure what those springs are rated for, but if memory serves correct, the spring compresses and inch for every hundred pounds or something like that. I just put icon 700# coils on my fox 2.0s. if i had the coin to do it all over again, i would have went with king.
    Blandino[OP] likes this.
  3. Jun 25, 2017 at 8:28 PM
    Blandino
    Damien
    Whistle Tip Exhaust
    Why do you say that? I just ordered the Fox 2.5's for my LT. An inch per 100lbs seems like a lot, but that would explain the sag.
  4. Jun 25, 2017 at 8:57 PM
    Blandino
    Damien
    Whistle Tip Exhaust
    Sent the folks at bilsteinlifts an email to see if the weight was the cause of this. They asked for the hub to fender measurements. The rear is 25", which seems about average with the dakar leaf pack going off: https://www.tacomaworld.com/threads/2nd-gen-ome-dakar-hub-to-fender-measurements.173193/
    I Didn't realize how low the front is now, it came in just under 22". Can't seem to find a measurement for the 5100's w/ toytec coils on 2nd clip/spacers should be though. Anyone that can check?
  5. Jun 26, 2017 at 4:16 AM
    captn.fat.beard
    Anthony
    NJ & Philly PA
    13' DCSB on 33"
    i noticed the sag about 100 miles after my suspension was installed. i could only imagine how low it'd be with a bumper/winch combo.
  6. Jun 30, 2017 at 8:48 AM
    95redrado
    95redrado Member
    Vancouver BC Canada
    07 dclb trd sport
    toytec 3 inc lift, 265/70/17 bfg k02's, trd exhaust, relentless fab aluminum bmp, smittybilt rtt
    I've noticed the same thing and I have the same setup as you, I have about 20,000 km on my lift so far and I added a relentless fab aluminum front bumper but no winch. I'm currently sitting at 22 inches hub to fender front and 24.5 rear. I'm going in on Tuesday next week to get the perches set to the second clip to help level it back out, unless you all convince me bumping it one will be enough. I will keep you posted on how it goes!
  7. Jun 30, 2017 at 7:37 PM
    Blandino
    Damien
    Whistle Tip Exhaust
    I should've probably done my research and checked how the additional weight would affect it. I'm just surprised that such little weight would cause it to sag significantly. It looks like getting the Fox 2.5's are going to take a lot longer than expected.
  8. Jul 1, 2017 at 4:58 AM
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    OME 886's are designed for additional front weight on Tacomas.
  9. Jul 1, 2017 at 5:24 AM
    Doublecross
    Doublecross Well-Known Member
    Robbie
    New york
    Work in progress
    ARE cap, wade inchannel vent visors, weathertec floor mats, ranch hand grill guard, tuffy security boxes in bed, lockable tailgate handle. Still have stuff that needs to be installed and still have stuff ordered lol.
    i have 886 with my bilsteins bottom setting no sagging
  10. Jul 1, 2017 at 11:56 AM
    FlyinTacoma
    FlyinTacoma Member
    Travis
    W 111' 35' N 33' 26'
    '15 DCSB TRD OR MT Super White
    Toytec 650lb Coils Dakar 3 leaf AAP Bilstein 5100 F&R JBA UCAs Rear axle shim Diff drop Sway Bar Delete Toyo Open Country A/T II Pro Comp Wheels
    The stock springs are rated to 540# from what I understand, and the lift you've got comes with 600# springs. So I would expect a fair amount of sag by adding 135# to the front end.
  11. Jul 1, 2017 at 8:49 PM
    Blandino
    Damien
    Whistle Tip Exhaust
    That's a good point. The parts I added totaled about 135lbs. If you consider the +60lbs from the beefier coils, we're only sitting at an additional 75lbs for the Toytec Ultimate setup. Then deduct the weight of the OEM bumper, fog lights, mounts, braces, inner fender wells, and skid plate. I'd say all of those would add up to at least 25lbs. So in reality it is only 50 pounds or less over intended weight, right?
  12. Jul 1, 2017 at 9:43 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    It's not just the weight, it's where the weight is located. Any weight added at the far ends of the vehicle is going to have a bigger effect on the suspension than weight added in the middle.
    FlyinTacoma likes this.
  13. Jul 4, 2017 at 9:21 AM
    Blandino
    Damien
    Whistle Tip Exhaust
    Do folks typically do the math for weight distribution before deciding what coils to use? Haven't found any threads discussing that yet. I can't see the variances between 3' to 2' of weight in front of a shock really making a large difference. For a truck that is designed to haul up to three additional passengers, potentially 900lb+ in America, I can't see 50 lbs as a legitimate reason for suspension to drop two inches. Obviously it happened, and I'm going to get adjustable coils. It just seems like this setup isn't worth it when you can pay a little more for a fully adjustable setup.
  14. Jul 4, 2017 at 9:44 AM
    Maticuno
    2011 Suburban 2500
  15. Jul 4, 2017 at 10:00 AM
    Blandino
    Damien
    Whistle Tip Exhaust
    I'm not disagreeing that weight and distribution of it affects the suspension. I work in aviation and am familiar with the importance of weight and balance. All I said was:
    I'm not saying it doesn't make a difference. I'm only saying with truck suspension I shouldn't lose an inch of clearance if I don't shit before I head to work.
    6Thick and Durdy like this.
  16. Jul 5, 2017 at 7:31 PM
    95redrado
    95redrado Member
    Vancouver BC Canada
    07 dclb trd sport
    well just an update got the truck back on Tuesday after setting the bilstiens to the 0.85 setting, I would say i'm leveled back out 24.5 rear, 23.9 (up from 22)front hub to fender gap. I may loose a little in the front when I add the winch, but overall i'm happy. however I still have stock upper arms and I need to get some aftermarket UCA probably within the next year to get it back in spec but i'm only out on my camber by 0.1 which isn't a big deal to me.
  17. Jul 6, 2017 at 6:38 AM
    Blandino
    Damien
    Whistle Tip Exhaust
    That's great it worked out. I'm jealous!
