Bilstein 5100 TRD off Road question
Discussion in 'Suspension' started by White Taco85, Jul 29, 2012.
  1. Jul 29, 2012 at 4:26 PM
    White Taco85
    White Taco85 [OP] Active Member
    South Carolina
    05 TRD-Off Road
    My plan please let me know if i am wrong. I want a small lift on my Taco i have a leveling kit on right now and do not like it so i want to take it off and put Bilstein 5100 on all around and want to set them to 1.75
    http://www.tacomaworld.com/out.php?...ma-pre-runner-4wd-ride-height-adjustable.html
    I read some where that it is not a good idea to use the 5100 with stock coils if you have a TRD off road.... is this true or do i need to get new coils as well?
    also in the rear i want to use ICON Toyota Tacoma '05-up Rear Add a Leaf Kit but i want to remain somewhat level or should i just remain stock in the rear with the exception of the 5100
    http://downsouthmotorsports.com/i-4764011-icon-toyota-tacoma-05-up-rear-add-a-leaf-kit.html
    Thanks for any information...
  2. Jul 30, 2012 at 12:12 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    there's tons of people who run the 5100's with stock coils. it may stiffen the ride since you're compressing the coils but they work fine.
    The alternative is to combine them with toytec's coils, which give 2nd gens 1.75" of lift
    combining either of those front lifts with icon's AAL might end up with a little bit of rake, it's completely up to you whether or not you want to lift the rear (If you're going to wheel any I would :D)
  3. Jul 30, 2012 at 7:59 AM
    White Taco85
    South Carolina
    05 TRD-Off Road
    First off thanks for the information but forgive me for being stupid but what do u mean a little bit of rake?
  4. Jul 30, 2012 at 10:17 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    rake = slant in suspension
    if you raise the front 1.75 and the rear 1.5 you'll be a tiny bit higher in the back, since trucks come from the factory a few inches higher in the rear
    (Evens the truck out when there's a load in the bed)
