Bilstein 5100 upgrade front
Discussion in 'Suspension' started by TraumaTaco, Jan 19, 2018.
  1. Jan 19, 2018 at 4:23 PM
    TraumaTaco
    TraumaTaco [OP] Member
    2009 Tacoma Off-Road 4x4
    New to the Tacoma forum and have a question regarding my ‘09 Tacoma dbl cab 4x4 off road with 180k. I’ve ordered Bilstein 5100’s for the front and wondered if and what joints and/or bushings should be replaced while I’m there. I have not noticed any problems. I’m not wanting to do anything extreme or expensive.
    TXpro4X4 likes this.
  2. Jan 19, 2018 at 4:25 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Welcome.
    I'm not sure about the U-joints but I don't think bushings are replaceable and if you're not understanding a squeaking cracking popping or anything weird and I don't see why they would need replacement.
    @HeadStrong Off-Road
    Might be able to help
    HeadStrong Off-Road likes this.
  3. Jan 19, 2018 at 4:30 PM
    TraumaTaco
    Thanks for the reply. I’ve noticed some slack on the rear when I rotated my at3’s recently. I’ll definitely consider that. I was wondering if I should even bother with the tierod ends or ball joints or sway arm in the front. Nothing has been an issue so far, but...
  4. Jan 19, 2018 at 4:32 PM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    You original owner?
  5. Jan 19, 2018 at 4:39 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Unless they’re worn out, no need. It’s not common for them to prematurely wear out. Just do a normal inspection, check for excessive play. If there is none, then no need to replace.
  6. Jan 19, 2018 at 4:41 PM
    TraumaTaco
    Thanks.
  7. Jan 19, 2018 at 4:46 PM
    TraumaTaco
    Bought it with 50k on it in 2011. Sees little off road, but I commute 1 hour to work. I’ve done well on its fluid changes though. Only problem I’ve had was the front wheel bearings being replaced.
  8. Jan 19, 2018 at 5:07 PM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Then I would think preventive maintenance would be it
  9. Jan 19, 2018 at 5:10 PM
    TraumaTaco
    I concur. Thanks. I plan on running this one another year then considering the new Pro series in DC 4x4.
  10. Jan 19, 2018 at 6:36 PM
    Pigpen
    Dan
    Northwest Montana
    You may find that your lower control arm (LCA) bushings are seized, making the installation of the shocks a challenge. If so, you will not be able to align the truck. Also, if lifting it, you will probably start hearing a pulsing vibration between 30 and 45 mph. That's the shitty needle bearing in your front differential.
  11. Jan 19, 2018 at 7:54 PM
    TraumaTaco
    Hmm... That's good to know and why I’ve posted such questions. Now I’m concerned. I wasn’t planning on lifting it more than .50 inches on the adjustable 5100’s. I guess a lot will depend on when I do this and if the LCA bushings are seized. The shocks do need replaced however. I assume if I was to buy knew LCA’s, problem solved?
  12. Jan 19, 2018 at 7:58 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    1.75
    2.5
    Typical 5100 lift ranges for 2nd gens
  13. Jan 19, 2018 at 8:10 PM
    TraumaTaco
    Will 0 still give it lift?
  14. Jan 19, 2018 at 8:11 PM
    inwood customs
    Dave
    No
    Unless u get lift coils
  15. Jan 19, 2018 at 8:36 PM
    TraumaTaco
    K. Thanks.
  16. Jan 21, 2018 at 2:57 PM
    lungfish23
    lungfish23 Well-Known Member
    BC, Canada
    Black 2014 trd sport
    I tried posting the the FAQ post but didn't get any replies and also don't want to start a brand new thread for just a quick question.
    But:
    I'm about to install some 5100s all around. I will be using stock coils for now, but I have a set of 3rd get Off-Road coils and a set of 2nd Gen Off-Road coils that I can install on them. Which ones should I choose? I have a 2nd gen Tacoma. What watch perch would I use? I'm assuming 3rd gen coils are longer so I wouldn't have to pre-load them as much?
    I am currently running 3rd gen suspenison on my 2nd gen because it leveled out the truck and was free. Just wondering which ones to put on the bilsteins.
    Thanks
