Bilstein 5100 w/ Eibach Coils
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoman15, Aug 22, 2011.
  1. Aug 22, 2011 at 11:45 AM
    tacoman15
    tacoman15 [OP] Boobies
    Northeast Georgia
    2015 Tacoma TRD OR & 1985 SR5 4Runner
    OK don't freak out on me because I am making another thread about this set up. I have been reading threads about this for the past hour but I still have not been able to decipher what I should do lol. I would like to run this set up with optimum ride height but people say different things about what setting you should/should not set your shocks to. So, with that being said...
    What setting should the front shocks (with the coils) be at for maximum height and not break?
    What setting should the back shocks (with coils?) be at for maximum height and not break?
    Also what should I expect to spend for all four bilsten 5100 shocks and eibach coils?
  2. Aug 22, 2011 at 11:49 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    The rear suspension setups of our trucks are leaf springs on a solid axle, so there are no rear coils and rear shocks do not add lift.
    on 2nd gens, to get the full 3 inches you need to set the 5100's to the first setting, then have the coils put on tip of that. (Either the 1st or middle setting..I'm a 1st gen so i'm not too sure)
    To lift the back you need to either put a block, add-a-leaf, or a new leaf pack.
    And 5100's from downsouth motorsports are the cheapest, with coils from toytec. I'll look up the links for you in a sec.
    Edit: links-
    http://downsouthmotorsports.com/i-1...acoma-pre-runner-4wd-pre-load-adjustable.html
    300 for the 5100's. But theres a TW discount that'll lower that.
    http://www.toyteclifts.com/index.ph...tegory_id=115&option=com_virtuemart&Itemid=72
    150 for the coils. toytec has a discount code as well.
    If you want to lift the back, toytec has a add-a-leaf as well
    http://www.toyteclifts.com/index.ph...tegory_id=116&option=com_virtuemart&Itemid=72
    for $78
    The billy/toytec/eibach setup is what I have on mine, it's a great cheaper lift.
    Hope this helps! :bananadance:
    AtMR2525 likes this.
  3. Aug 22, 2011 at 11:51 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    See above in bold.
  4. Aug 22, 2011 at 11:55 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    ha. Beat you :bananadance: :bananadance: :bananadance: :bananadance:
  5. Aug 22, 2011 at 12:01 PM
    tacoman15
    Northeast Georgia
    Thanks!!! I know this is probably a really dumb question but when you say billy/toytec/eibach/ setup what does billy stand for? Also when I was reading stuff about this people kept referring to AAL's? What are those?
  6. Aug 22, 2011 at 12:03 PM
    Pugga
    Massachusetts
    F-150 Mod
    Billy - Bilstein 5100's
    AAL - Add-a-leaf
    You might want to read up a little more on the Tacoma suspension. This thread is full of very useful info and is a good starting point.
    http://www.tacomaworld.com/forum/suspension/11282-tacoma-lift-faq-guide-read.html
  7. Aug 22, 2011 at 12:04 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    billy = bilstein 5100
    AAL = add a leaf.
    toytec is a brand/company
    eibach is a brand of spring
  8. Aug 22, 2011 at 12:06 PM
    Pugga
    Massachusetts
    F-150 Mod
    Yeah yeah... I'm at work and running a little slow. :cool:
  9. Aug 22, 2011 at 12:22 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    AALs or add-a-leaf's are just that- they add a leaf into your leaf pack to give you lift.
    If you look under your truck, in the back theres metal "leafs" that act as an articulating bow. They flex up and down depending on the driving surface- and theres more than one of them. Adding a leaf increases the arch of the leaf pack as a whole, providing lift.
  10. Aug 22, 2011 at 1:02 PM
    tacoman15
    Northeast Georgia
    Haha wow that was a dumb question. Thanks for all the help guys! One last question though...how big of a tire will I be able to fit with the billy/toytec/eibach set up plus an ALL?
  11. Aug 22, 2011 at 1:07 PM
    Pugga
    Massachusetts
    F-150 Mod
    265/75R16 without trimming I believe and 285/75R16 with some trimming involved.
  12. Aug 22, 2011 at 1:11 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner
    Stuff
    Yup yup
  13. Aug 22, 2011 at 1:19 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    I had 285's with a 3" lift and it would rub hardcore on the cab mounts when wheeling. normal on rode driving it wouldnt at all though. so the people tell you that all you have to do is remove the mudd flaps are either mall crawlers or full of shit
  14. Aug 22, 2011 at 1:22 PM
    BlueTaco07
    BlueTaco07 Super Mod!
    Cody
    Panama city, Florida
    Looking
    set the 5100's to .85 second setting with eibachs and top plate spacers you achieve just over a 3" but right at it. With that said running the toytec 2" AAL and 5100's in the rear it sits almost level
  15. Aug 22, 2011 at 1:28 PM
    tacoman15
    Northeast Georgia
    Will it come with top plate spacers?
  16. Aug 22, 2011 at 1:29 PM
    BlueTaco07
    Cody
    Looking
    Go to toyteclifts.com just get the whole lift kit and you can add them to it for like 59.00.
  17. Aug 22, 2011 at 2:12 PM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    265/75 here w/ no trimming
  18. Aug 22, 2011 at 5:24 PM
    tacoman15
    Northeast Georgia
    Where are the discount codes you were talking about???
  19. Aug 22, 2011 at 6:29 PM
    Pugga
    Massachusetts
    F-150 Mod
    They have discount codes within their respective vendor sections just for us members :D
    http://www.tacomaworld.com/forum/vendors/
  20. Aug 22, 2011 at 7:29 PM
    tacoman15
    Northeast Georgia
