Bilstein 5100 w/ OME 885
Discussion in 'Suspension' started by austinaa98, Jan 11, 2016.
  1. Jul 30, 2017 at 2:54 PM
    #281
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    No, they'll be fine. You get different measurements from all vendors for some reasons. I've had one rear wheel in the air numerous times with a 2" aal and 5100s, and it was fine. The shock wasn't the limiting factor.
    GeauxTigers[QUOTED] likes this.
  2. Jul 30, 2017 at 2:55 PM
    #282
    GeauxTigers
    GeauxTigers //TRD
    Caleb
    Sterlington, Louisiana
    '14 TRD DCSB Off-Road 4x4
    265/70/17 BFG KO2/17"x7" Pro Sema Wheels/OME 884/Bilstein 5100 front & rear/HeadStrong 1/4" TP spacer/Deaver 1.5"-2" AAL/Mud-Flap delete/Westin Bed mat/UltraGauge/ WeatherTechs/AFE Pro Dry Drop in Filter/debadged/AVS in-channel window visors/color-matched OEM grille/Kicker 6.75" Components in front door/Alpine KTP-445U power pack behind factory head unit/
    Awesome. Appreciate it! What's the deciding factor on 1/4" or 1/2" top plate spacer?
  3. Jul 30, 2017 at 3:02 PM
    #283
    mosquitoTaco
    mosquitoTaco Has an attractive member
    Anthony
    SouthTennessee
    14' DCSB offroadsport-sold =2005 T4R V8
    Bilstien 5100@ 0, OME 885(+10 mm drivers side spacer for taco lean, 5mm passenger), b110 rears w/ allpro standard leaf pack, wheelers ubolt flip, superbump bump stops, extended brake lines steal braided(front and rear), Dick Cepek extreme country 305/65/17 tires on FN six shooters=17x8, street tires are 285/75/16 duratrac w/FN countersteer type X= 16x8, a healthy cab mount chop, SPC LR UCA's, TC cam tab gussets, Wet okole seat covers, husky x-act fit floor liners, SOS aluminum front skid, SOS mid skid, SOS sliders (bolt on), ECGS bushing for needle bearing, uniden PRO520XL cb. BAMF tailgate antenna mount, 4' firestick, A.R.E. Z series camper top, Factory roof rack, Pioneer avh-5800x head unit. Front and rear anytime cameras, Rear diff. Breather relocate. 42" highlift. Tow straps/All-PRO snatch strap, tow hitch w/D-ring, traction pads, Tacoma bed mat, Rago Fab ditch light brackets with jap special light pods
    1/4 is what is have for drivers lean
  4. Jul 30, 2017 at 3:04 PM
    #284
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    1/4 generally goes on the drivers side to compensate for taco lean, and can be used with the regular length studs. 1/2 is generally to get a full 3", and requires longer studs. I have neither on my truck.
  5. Jul 30, 2017 at 3:06 PM
    #285
    Nimbostratus
    Nimbostratus Well-Known Member
    Tuscaloosa, AL
    2019 Toyota Tacoma TRD-OFFROAD
    Anyone running 285/70/17 with method wheels on this setup? Looking to get the 5100s in front and rear with OME 885s. Wanting to go with a 285/70/17 ridge grappler or ko2. Just curious if anyone had this exact setup.
  6. Jul 30, 2017 at 3:30 PM
    #286
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    I have been using the rear 5100's for awhile no complaints or over extending.Contact @HeadStrong Off-Road they will provide you with the right parts.
  7. Jul 30, 2017 at 3:43 PM
    #287
    GeauxTigers
    GeauxTigers //TRD
    Caleb
    Thanks fellas. Time to go shopping. I'll be glad to get rid of this spacer lift the previous owner installed.
    EatSleepTacos likes this.
  8. Jul 30, 2017 at 3:55 PM
    #288
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Also PM @Wheeler's Off-Road Inc for a quote. They were able to beat headstrong by a decent bit for me.
  9. Jul 31, 2017 at 5:36 PM
    #289
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    Thank you so much @TacoTRD78 :cheers:
    If there is anything I can help you out with @GeauxTigers just let me know :thumbsup:
    TacoTRD78[QUOTED] likes this.
  10. Jul 31, 2017 at 6:06 PM
    #290
    GeauxTigers
    GeauxTigers //TRD
    Caleb
    Thanks Marie,
    I'm definitely in the market. Have been looking all over at prices and trying to decide the exact route I want to take.
    I'm going to try to purchase in phases so I don't make the wifey mad. :rofl:
    Marie, could you shoot me a quote on just the Bilstein fronts with OME 885x coils, a 1/4" top plate spacer, and preinstalled?
    Thanks!
  11. Jul 31, 2017 at 7:34 PM
    #291
    TRD2010SpeedwayBlue
    TRD2010SpeedwayBlue Well-Known Member
    Brandon
    2010 Speedway Blue TRD Offroad
    ok so maby i missed it and have to read back, if i do someone let me know.
    But what should my alignment specs be for 5100's with 885's 1/4 inch headstrong off road top spacer and TOTAL CHAOS UCA's.
    i wanted to know what my specs should be so once it's installed and i take it somewheres for alignment i know what to tell them so i dont have any problems
  12. Aug 1, 2017 at 4:22 AM
    #292
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Shoot for 0° toe/camber and around 2.5° of caster. Too little caster and your steering will feel twitchy at highway speeds.
  13. Aug 1, 2017 at 4:26 AM
    #293
    TRD2010SpeedwayBlue
    Brandon
    so those are the only 2 things i should tell the shop to make sure to set to exact as good as they can get? and rest stock specs?
  14. Aug 1, 2017 at 4:33 AM
    #294
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    3 things. 0° toe, 0° camber, and 2.5°ish caster. Remember this is a ballpark as well, and it's tough for them to get exact numbers. Those are the three main things to worry about with an alignment.
  15. Aug 1, 2017 at 5:58 AM
    #295
    TRD2010SpeedwayBlue
    Brandon
    alright cool. ill keep that in mind. anywheres within 1-3 degree of those numbers if cant get exact will be fine correct?
    just want to make sure my trucks aligned properly after lift so i dont have any steering/vibration or any other issues.
    also will be running the headstrong AAL for the rear if wondering i think i was going to leave the overload leaf in. but really wasnt sure what the best option would be.
    no towing or any extra weight will be done/in the rear
  16. Aug 1, 2017 at 6:02 AM
    #296
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Each thing has its own range of numbers that's acceptable. For example, getting 0° toe is extremely easy, so that one can be spot on. For camber, it's around 0.5° in either direction that's fine (going off memory) and for caster, you'll never get too much. For example, on stock UCAs I was only able to get 1.56° caster without sacrificing camber, so I went with it. Steering is a little twitchy that low though. So pretty much get as much as you can, up to 2.5-3°
  17. Aug 1, 2017 at 11:14 AM
    #297
    HeadStrong Off-Road
    PM sent :cheers:
  18. Aug 1, 2017 at 1:31 PM
    #298
    TRD2010SpeedwayBlue
    Brandon
    sounds good!
    now i just have to figure out who is going to install my lift and give me a hand. my one friend was suppose to buy we dont talk anymore bc of childish shit.
  19. Aug 1, 2017 at 1:36 PM
    #299
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Where are you located?
  20. Aug 1, 2017 at 1:39 PM
    #300
    TRD2010SpeedwayBlue
    Brandon
    Albany ny.
    my one buddy kyle had his suspension taken apart and said he would
    help me do it. but he is iffy about the uca's. as he has never doneit before.
    my other buddy said hed do it and get ahold of him but he is impossible to get ahold of
