Bilstein 5100 w/ OME 885
Discussion in 'Suspension' started by austinaa98, Jan 11, 2016.
  1. Aug 3, 2017 at 9:51 AM
    #341
    TRD2010SpeedwayBlue
    TRD2010SpeedwayBlue Well-Known Member
    Brandon
    2010 Speedway Blue TRD Offroad
    thanks for being so helpful man i appreciate it!
    also after i install everything i should get it aligned asap right? i drive 30 miles highway round trip to work mon-fri. prob shouldnt drive to work a few days un aligned right?
  2. Aug 3, 2017 at 9:52 AM
    #342
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    While it's not the end of the world to drive it for a few days, I'd get it aligned ASAP. With that being said, you'd most likely be fine for a couple days. May just get some premature tire wear.
    99TacoDriver likes this.
  3. Aug 15, 2017 at 11:57 PM
    #343
    vtac
    vtac Well-Known Member
    2017 Tacoma TRD OR DCSB
    Why os the 5100s and OME coils favourable? why not go with OME shocks+OME coils? one would think they were designed for each other? Noobie needs help
  4. Aug 16, 2017 at 7:13 AM
    #344
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    Some people favor the 5100s because they are a monotube, high pressure gas shock while the OME shock is a twin tube, low pressure. (This changes the way they feel while driving)
    Basically the billies are a little bit better at dissipating heat which helps their performance.
    vtac[QUOTED] likes this.
  5. Aug 16, 2017 at 7:56 AM
    #345
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    For me it's because they're cheaper.
    Catfish21, 61ragtop and vtac[QUOTED] like this.
  6. Aug 16, 2017 at 9:40 AM
    #346
    vtac
    Thanks for replying. So how does one feel compared to the other when driving?
    I still can't decide whether to go for this
    Old Man Emu medium coils for front
    Bilstein 5100 shocks front and rear
    Old Man Emu Dakar leaf springs
    Old Man Emu bushing kit
    ARB u-bolts
    OR
    Old Man Emu shocks front and rear
    ARB u-bolts
    99TacoDriver[QUOTED] likes this.
  7. Aug 16, 2017 at 9:44 AM
    #347
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    BAMF RCLT Deaver Fox 2.5 StopTech Dana 60 37s 475:1
    EatSleepTacos,
    Which coil springs are you running and at what setting on the Bilsteins?
    EatSleepTacos likes this.
  8. Aug 16, 2017 at 10:07 AM
    #348
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'm running the 884 coils with the 5100s on 0 which gave me just under 3" of lift on my truck. If you run any ome coil, leave it at 0 because otherwise it'll ride harsher.
    TacoEspecial[QUOTED] likes this.
  9. Aug 16, 2017 at 10:57 AM
    #349
    99TacoDriver
    South Louisiana
    I really can't speak from experience on how the ride feels for the OME
    I can say that I have the 5100 and 885 coils and I am satisfied with the way it sits and rides.
    As for the rear, I can't speak on that either because I have an AAL
  10. Aug 16, 2017 at 1:30 PM
    #350
    vtac
    It is done. I just put an order in with the 5100s! pumped!
  11. Aug 16, 2017 at 1:38 PM
    #351
    99TacoDriver
    South Louisiana
    Congrats, what size coil did you go with?
  12. Aug 16, 2017 at 2:54 PM
    #352
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    If i want a 2in lift, would 885/5100 and 2in aal be the way to go? DCSB 4x4. Marie said the 884s are fine but would it settle past the 2in mark?
  13. Aug 16, 2017 at 3:20 PM
    #353
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    884s would be what you want. I had 885s with a 2" AAL and got ~2.5" in the front.
    outxider[QUOTED] likes this.
  14. Aug 16, 2017 at 3:24 PM
    #354
    vtac
    G
    Going with 888s. Honestly don't know much about the coils. Just what my local shop suggested given my usage.
  15. Aug 16, 2017 at 3:29 PM
    #355
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    They made the right choice. That'll give you 2.5"-2.75" of lift with your truck.
    vtac[QUOTED] and 99TacoDriver like this.
  16. Aug 16, 2017 at 3:45 PM
    #356
    vtac
    Nice just what I wanted! Thnx
    EatSleepTacos[QUOTED] likes this.
  17. Aug 17, 2017 at 2:12 PM
    #357
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    You're also getting aftermarket UCA's right? Anything over 2 inches will likely require replacing the stock UCA's in order to get a decent alignment. That added expense and maintenance is one of the reasons I stayed below 2 inches.
  18. Aug 17, 2017 at 3:11 PM
    #358
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Not entirely true. I have a little less than 3" on stock ucas, and was able to get 1.6 degrees of caster. It's not the best, but I'd consider it decent. Steering is a little twitchy above 75 mph, but I rarely drive that fast anyways and even when I do, I still feel very safe and stable in my truck.
  19. Aug 17, 2017 at 3:15 PM
    #359
    Nimbostratus
    Nimbostratus Well-Known Member
    Tuscaloosa, AL
    2019 Toyota Tacoma TRD-OFFROAD
    Are you guys running a small top plate spacer on top of the 885s with the 5100s set at 0 to run 285s? I placed an order with wheelers off-road today and they recommended the small top spacer to give a litte additional lift to accommodate the 285s.
  20. Aug 17, 2017 at 3:17 PM
    #360
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That little bit of extra lift isn't going to guarantee you to be able to fit 285s. Once the tire hits a bump and is compressed into the wheel well, lift isn't a factor anymore. You're pretty much guaranteed to have to trim plastic, and pretty likely to have to do a CMC in order to not rub.
