Bilstein 5100 w/ OME 885
Discussion in 'Suspension' started by austinaa98, Jan 11, 2016.
  1. Aug 17, 2017 at 3:23 PM
    #361
    Nimbostratus
    Nimbostratus Well-Known Member
    Tuscaloosa, AL
    2019 Toyota Tacoma TRD-OFFROAD
    I'm okay with that. Just curious if others had done the same with the coil/shock combo. Also are you guys running differential drop kits? I've heard some people say you need it and others say not to waste your money.
  2. Aug 17, 2017 at 3:24 PM
    #362
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It's a matter of personal opinion, as it's a hot topic around here. I ran one on my last truck, but not on this truck and have no plans to. Since it's inexpensive and helps a little bit, no harm in running it.
    Nimbostratus[QUOTED] likes this.
  3. Aug 17, 2017 at 3:41 PM
    #363
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    I run a 1/4 inch spacer on the driver's side to compensate for lean, not to run a larger tire. I have 265/70/17.
    No diff drop as I'm just under 2 inches front and back.
  4. Aug 17, 2017 at 4:07 PM
    #364
    Nimbostratus
    Tuscaloosa, AL
    Gotcha. Just didn't know if I made a mistake going with those spacers since I'll be running factory ucas.
  5. Aug 17, 2017 at 4:18 PM
    #365
    mosquitoTaco
    mosquitoTaco Has an attractive member
    Anthony
    SouthTennessee
    14' DCSB offroadsport-sold =2005 T4R V8
    Bilstien 5100@ 0, OME 885(+10 mm drivers side spacer for taco lean, 5mm passenger), b110 rears w/ allpro standard leaf pack, wheelers ubolt flip, superbump bump stops, extended brake lines steal braided(front and rear), Dick Cepek extreme country 305/65/17 tires on FN six shooters=17x8, street tires are 285/75/16 duratrac w/FN countersteer type X= 16x8, a healthy cab mount chop, SPC LR UCA's, TC cam tab gussets, Wet okole seat covers, husky x-act fit floor liners, SOS aluminum front skid, SOS mid skid, SOS sliders (bolt on), ECGS bushing for needle bearing, uniden PRO520XL cb. BAMF tailgate antenna mount, 4' firestick, A.R.E. Z series camper top, Factory roof rack, Pioneer avh-5800x head unit. Front and rear anytime cameras, Rear diff. Breather relocate. 42" highlift. Tow straps/All-PRO snatch strap, tow hitch w/D-ring, traction pads, Tacoma bed mat, Rago Fab ditch light brackets with jap special light pods
    Same here, only the 1/4 on the drivers side, and as stated previously 285 don't clear because of lift, if I put my factory suspension back on I would still clear my 305s, once the shock compresses and your wheel stuffs you are back to stock anyway, otherwise don't hit bumps :D, you will need to trim/bend around some plastics and most likely a CMC, alignment specs will help with the cab mount
  6. Aug 17, 2017 at 4:19 PM
    #366
    Nimbostratus
    Tuscaloosa, AL
    Should I be okay running stock UCAS?
  7. Aug 17, 2017 at 4:22 PM
    #367
    mosquitoTaco
    Anthony
    SouthTennessee
    If you are using the top plate spacer on both sides it will be hit or miss, I had no problem with my alignment with stock uca, I now have spc UCA's but only because I got a good deal on them.
  8. Aug 17, 2017 at 4:22 PM
    #368
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Exactly. No one can definitively say for sure one way or another.
    mosquitoTaco[QUOTED] likes this.
  9. Aug 17, 2017 at 5:10 PM
    #369
    Nimbostratus
    Tuscaloosa, AL
    Is anyone else running 285s with the 5100/885 setup?
  10. Aug 17, 2017 at 5:14 PM
    #370
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I did on my last truck. Not top plate spacers at all. Did the CMC, trimmed some plastic, and hammered the pinch weld and had minimal rubbing off-road.
    Catfish21, jerzsubbie and TacoTrooper like this.
  11. Aug 17, 2017 at 5:19 PM
    #371
    Nimbostratus
    Tuscaloosa, AL
    Looks great! Hopefully I don't have to do all that. I'm not familiar with the pinch weld mod but I'll look it up. Just would like to see pictures like this and other experiences with that size. I ordered 285/70/17 ko2s with method standard wheels if that makes a difference.
  12. Aug 17, 2017 at 5:20 PM
    #372
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Here's info on the pinch weld.
    https://www.tacomaworld.com/threads...lat-with-a-sledge-hammer-lets-discuss.425850/
    It's basically pulling the plastic liner back, hammering the weld with a BFH, then putting the liner back.
  13. Aug 17, 2017 at 5:51 PM
    #373
    mosquitoTaco
    Anthony
    SouthTennessee
    Why do I remember these pics, Florida apparently if Chris took them....
  14. Aug 17, 2017 at 5:53 PM
    #374
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Are you part of the panhandle toyota FB page?
  15. Aug 17, 2017 at 5:54 PM
    #375
    mosquitoTaco
    Anthony
    SouthTennessee
    No I live in central fl, go to the annual citrus every year
  16. Aug 17, 2017 at 5:55 PM
    #376
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    :notsure: I do post these pics alot. I really like them.
  17. Aug 18, 2017 at 5:55 PM
    #377
    vtac
    vtac Well-Known Member
    2017 Tacoma TRD OR DCSB
    @EatSleepTacos So I got my lift put on today. The mechanic set the circlip onthe second from bottom notch at 0.67" on 888 coils. Will I run into issues? I feel like I'm getting a lot of the road feel through the steering wheel. Does it need to settle in?
    EatSleepTacos[QUOTED] likes this.
  18. Aug 18, 2017 at 5:57 PM
    #378
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    No, what you feel is what you get. It's because the coil is preloaded to gain more lift, but it results in a harsher ride. Another thing to potentially smooth out the ride is to drop your tire pressure. Depending what it's at, lower is better.
    speedtre likes this.
  19. Aug 18, 2017 at 6:00 PM
    #379
    vtac
    Would putting it at stock 0 setting mitigate anything?
  20. Aug 18, 2017 at 6:00 PM
    #380
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Yes, removes preloading the coil. For 5100s to achieve lift is been recommended to run taller aftermarket springs at 0 or preload the stock springs with the clip. Preloading g gives you lift but a stiffer ride. You just compressed larger springs to make it even stiffer.
