Bilstein 5100 w/ OME 885
Discussion in 'Suspension' started by austinaa98, Jan 11, 2016.
  1. Mar 25, 2016 at 4:44 AM
    #61
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    I believe it would be a ome 886 also
  2. Mar 25, 2016 at 4:50 AM
    #62
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    886's are a higher rate spring than the 885 or 887. Most vendors will tell you that they do NOT suggest using 886's with the 5100's....The 885 and 887 are very near the limit as far as being too stiff for the (non adjustable) rebound dampening of a 5100. But they will work. 886's are too stiff and over-work the rebound dampening that shock provides. You get a jackhammer effect while driving, and you get a short life expectancy for the shock. People have used 886's with 5100's but there is a very high incidence reported of premature shock failure.
    ezatnova and geekhouse23 like this.
  3. Mar 25, 2016 at 4:52 AM
    #63
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Typically why I tell people to get what is designed and built to work together..OME with OME and Bilstein with eibach
  4. Mar 25, 2016 at 5:02 AM
    #64
    Bluegrass Taco
    Bill
    Mt Washington Ky
    I'm golden with the 5100's and 885's.....After owning 4wds since the early 70's, 17 of them in fact, and working on (literally) hundreds of other trucks (for extra income) I have yet to ride in a truck that has the ride quality and comfort that I found when that combination went under my Tacoma. There are "mixed breed" combinations that work well. There are certain combinations that just don't work at all. Sometimes you have to cross borders to get the exact results you are looking for. Eibach didn't offer the height coil I was wanting...And I wanted the 5100's set @ 0"....So....Ya do what ya gotta do sometimes....
    With that, I've been told by a couple guys who've used the combination that the OME front shock "clunking" (topping out over bumps) is even more prevalent with 886's than with lighter rate springs. Never experienced that for myself, but..... It's just a VERY stiff rate spring for a relatively light weight truck.
    4x4cajun, FJ to Taco and shitgoose06 like this.
  5. Mar 25, 2016 at 5:06 AM
    #65
    geekhouse23
    I agree..I've become more aware of those using 5100's with OME coils up to 885's and they are loving the setup.
    That said, if they ever plan on going with 886 coils to run a plate bumper, winch, full skids, sliders etc..get OME shocks. They are designed to work with the 886 higher spring rates and won't prematurely wear like the 5100's would. If you are planning on doing this, you could sell your 5100/885 setup and make some decent money back than you would with blown 5100 shocks..I just like to think ahead and be prepared haha
    G3Fab, HipHead, shitgoose06 and 2 others like this.
  6. Mar 25, 2016 at 5:09 AM
    #66
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Yep.....I'm tempted to put my truck together with snaps and zippers.....Nothing seems to stay the way it is very long before "something better" comes along......Damn this website....
    Key-Rei and EMS911 like this.
  7. Mar 25, 2016 at 5:12 AM
    #67
    geekhouse23
    I know what you mean haha my rear suspension has been overhauled 3-4 times already and I think I have it where I want it finally. Just have the get it on the trail and test up/down travel and make sure brake lines and bump stops are set properly. Only thing that would ever change down the road are shocks (quality and valving etc)
    Bluegrass Taco likes this.
  8. Mar 25, 2016 at 5:18 AM
    #68
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Uh.....NEVER say never.....2 weeks ago, I said I was 100% happy with mine and done spending money for now. I'll be sending in the order for the NEXT new parts later this afternoon.
    Like an uncircumcised dick.....There's no end to this.....
  9. Mar 25, 2016 at 5:26 AM
    #69
    geekhouse23
    Haha oh man..well just in the last 2 weeks alone, I've gotten my rear suspension "finalized" for now :anonymous: with the BAMF shock relocation kit, 12" Bilstein 5125's and Bora .75" spacers and a Pelfreybilt front bumper and LED pods and fogs for the bumper.
    I think I've been pretty good this month selling a lot of stuff I don't need or will be using with this new setup..makes things easier on the fiancée with the wedding at the end of this month haha
    On to the next wants/needs on the to-do list..it never ends indeed
  10. Mar 25, 2016 at 5:29 AM
    #70
    Arailt
    Arailt Well-Known Member
    Dallas, TX
    2019 GX460
    Bilstein 5100s are designed to be used with factory coils, not Eibach. However, they work just as well with factory, Eibach, and OME coils.
    In fact, one could argue that they work better with OME coils than Eibach because OME coils (884/885) are closer to the factory spring rate.
    That said, there are plenty of people who run the 5100/886 combo with no issues. On the other hand, I see a lot of "topping out" complaints from guys with the OME/886 combo.
    geekhouse23[QUOTED] likes this.
  11. Mar 25, 2016 at 5:38 AM
    #71
    i_cappi
    i_cappi Well Known Membhair
    Canton, Oh
    2011 TX TuRD Pyrite DCSB
    I never did believe they were specific designed for our factory springs....I really have a hard time believing they took what our 2-3 different oem springs that come in our tacomas and specifically took 1 shock it tuned precisely to all tacoma spring types. From what I understood they were designed for the sport/sr5 springs and not the progressive off road springs.
  12. Mar 25, 2016 at 6:11 AM
    #72
    Arailt
    Dallas, TX
    2019 GX460
    I hear ya. I'm sure, just like everything else, "tuned for and/or designed for" are used loosely. Probably based on GVWR (+/- 500) and spring rate (+/- 100).
    Whether or not they are specifically tuned for any of them, Bilstein's advertised Tacoma lift heights apply to factory coils on SR5, Sport, and Off Road models.
    i_cappi[QUOTED] likes this.
  13. Mar 25, 2016 at 6:22 PM
    #73
    nizzmont
    nizzmont Well-Known Member
    Brian
    S.E WA state
    2015 doublecab TRD sport
    in progress
    well maybe the complete OME package is what I should go with and a pair of UCA,i cant afford a set of there leaf springs though,with getting back into bowhunting this jan I'm a little short on funds now lol
  14. Apr 15, 2016 at 1:04 AM
    #74
    JDR1011
    JDR1011 NINJA HELICOPTER MECHANIC
    Jeff
    mobile, al
    2012 MGM DCSB PRERUNNER SR5
    Plastidip grille, fog light anytime mod, Yakima roof racks & fairing, N-fab step bars, Husky floor liners, 16" black stock steel wheels, Softopper.
    So... 885 coils for DCSB, but what if you are a 4cyl prerunner DCSB? Should I use the 884 coils because of less weight from the smaller engine and no transfer case? I want to sit level with a 2" AAL in rear and 5100's all the way around. keeping stock UCA's, so got to make sure I don't go too high up front. Thanks in advance.
  15. Apr 15, 2016 at 4:12 AM
    #75
    zert808
    zert808 Well-Known Member
    D
    Mililani, HI
    2015 White Tacoma OR DCSB 4x4
    OME Lift Kit: Front 90021 shocks with 885 coils. Nitrochargers 60091 shocks in the rear. Medium Duty Dakar leaf pack. 17 in TRD rims wrapped with Nitto Ridge Grapplers in 265/70/17
    What's the eibach equivalent to the OME 885?
  16. Apr 22, 2016 at 10:54 AM
    #76
    Tac11
    Tac11 Well-Known Member
    Luis
    2011 white Tacoma sport TRD
    3" Front lift OME/5100 set at 0, 1/4 spacer on driver side CMC, BFG 285's, SCS ray 10’s -38 offset 1 inch rear block N-Fab steps Bumper Cali Raised LED light bar Cali Raised LED fog lights After market exhaust, and muffler tip Redline hood struts Tacoma Bed-liner mat Tailgate lock Tinted windows 20% HID headlights Short antenna Clazzio Seat covers Joying head unit
    I got 285 ko2 with my 17 rims. On a 3"lift. I hit at full lock or certain turning at my UCA. Bora .75 will fiX IT OR CAUSE MORE RUBING ELSEWHERE?
    Kmalloy likes this.
  17. Apr 22, 2016 at 10:59 AM
    #77
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Probably rub elsewhere, but you should be able to trim and fix that.
    saltytaco13 and ChadsPride like this.
  18. Apr 22, 2016 at 10:59 AM
    #78
    TacoTRD78
    Stuart,fl
    What size tires are you guys running with what kinda rim with bilsteins set a zero with 885 coils that dont rub?
  19. Apr 22, 2016 at 11:00 AM
    #79
    Tac11
    Luis
    Bfgk02 285 on stock sport 17"
  20. Jun 3, 2016 at 5:14 AM
    #80
    TacoTRD78
    Stuart,fl
    Hey Tac got any pics bro?Any rubbing?
