Bilstein 5100 with stock springs / Spacers??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gpfwvu, Dec 14, 2020.
  1. Dec 14, 2020 at 5:54 PM
    gpfwvu
    gpfwvu [OP] Active Member
    2011 Toyota Tacoma Long Bed 2WD
    Stock
    Tons of information about Bilsteins and springs on this forum but need confirmation as I could not find an exact answer to my situation.
    I have a 2005 4WD Long Bed Tacoma. It has 2" or 3" lift spacers in the front and a 1" block in the rear. I want to get Bilstein 5100's on all four corners.
    If I get Bilsteins, can I keep the front spacers or can I get the same current height by adjusting the shocks with the clips? I know each Tacoma is different but could use some confirmation/input.
    Thanks in advance!
  2. Dec 14, 2020 at 5:57 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    I wouldnt. The 5100's are Longer in extended length than stock shocks, and when paired with a lift spacer could make it to where you have too much droop. You would be better off ditching the spacer and setting the 5100 to the 1.75in or 2.5in setting (depending on your lift spacer amount)
    gpfwvu[OP] likes this.
  3. Dec 14, 2020 at 6:34 PM
    SocalTaco15
    SocalTaco15 Well-Known Member
    Glen
    Socal, Orange County
    Get 5100’s and coils which are designed to do the lifting, so you don’t sacrifice travel by using spacers.
    OME makes an assortment of coils to meet your needs.
  4. Dec 14, 2020 at 6:52 PM
    gpfwvu
    Stock
    I thought about that. The previous owner believes it is a 3" spacer in the front but he is not exactly sure. I want to make sure the truck stays level so I'm not sure which coil I would get? I'd hate to get coils and then learn the front is too low or two high once installed. Any suggestions?
    Thanks!
  5. Dec 14, 2020 at 7:18 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  6. Dec 14, 2020 at 7:24 PM
    DG92071
    DG92071 Well-Known Member
    Measure the spacer itself, a spacer that gives 3" of lift is exactly 1.5" thick.
    SocalTaco15 and TnShooter like this.
  7. Dec 15, 2020 at 5:42 PM
    gpfwvu
    Stock
    I appreciate that tip/advice because I looked at the spacer and it's not 2 or 3" in height. I didn't know that's how they measure. Sounds good. Thanks!
    DG92071[QUOTED] likes this.
  8. Dec 15, 2020 at 7:21 PM
    taco912
    taco912 Well-Known Member
    North of the Bridge
    2006 AC 4.0 AT 4x4 SR5 TRD OR
    I have never seen this posted but I found the same 2x relationship when setting the spring perch with the 5100; the spring perch adjustment rings are 3/4" apart and with each increments seemed to raise the front end 1 1/2". This was on a '06 OR with stock progressive springs. Please confirm for yourself or others comment.
