bilstein 5100 with top plate spacer?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco89, Apr 12, 2011.
  1. Apr 12, 2011 at 7:34 PM
    Taco89
    Taco89 [OP] Well-Known Member
    Nik
    Charlotte, NC
    2013 4x4 Super White DBL Cab TRD Sport
    I installed the bilstein 5100 set to 2.5" with 3/4" top plate spacers and 2" AAL...i got an alignment today but they said they couldnt get it perfect. My tires are still leaning a little in the front....would new UCA's fix this?
  2. Apr 12, 2011 at 8:17 PM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    I'm not sure about the safety of 2.5 w/ 3/4 top plate spacers. And yes, you need new UCA's. Prolly a diff drop as well if your 4x4.
  3. Apr 12, 2011 at 8:18 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    UCA's for sure
  4. Apr 12, 2011 at 8:23 PM
    Taco89
    Nik
    Charlotte, NC
    I have 2x4 and don't go off roading What's not safe about it? I don't really know much about all this I'm still learning
  5. Apr 12, 2011 at 8:29 PM
    OZ-T
    Peter North
    British Columbia
    It's not that it is unsafe , by lifting the front of the truck that much , you have changed the geometry up front and there is not enough adjustment in the stock UCA's to get a correct alignment .
    Aftermarket UCA's will allow for more adjustment .
  6. Apr 12, 2011 at 8:33 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Going over 3" total is generally a bad idea on these IFS's, because your ball joints can bind at full droop.
    Was the top plate spacer 3/4" thick?, or rated at 3/4" lift? Spacers lift twice their thickness.
  7. Apr 12, 2011 at 8:34 PM
    Taco89
    Nik
    Charlotte, NC
    Ohh okay cool thanks, so if I get new UCA's my tires will straighten up?
  8. Apr 12, 2011 at 8:35 PM
    OZ-T
    Peter North
    British Columbia
    You will be able to get it aligned properly , yes .
  9. Apr 12, 2011 at 8:36 PM
    OZ-T
    Peter North
    British Columbia
    On this ^^^ note OP , what is the thickness of your spacers ?
  10. Apr 12, 2011 at 8:36 PM
    Taco89
    Nik
    Charlotte, NC
    Its 3/4" thick
  11. Apr 12, 2011 at 8:37 PM
    OZ-T
    Peter North
    British Columbia
    What is your total lift ?
  12. Apr 12, 2011 at 8:38 PM
    KPT
    09 Prerunner
    So with the 5100's @ 2.5", and a 1.5" top plate spacer, you are at 4" of lift. That's not safe for any of your suspension components. Take the spacer out.
  13. Apr 12, 2011 at 8:39 PM
    OZ-T
    Peter North
    British Columbia
    Agreed
  14. Apr 12, 2011 at 8:47 PM
    Taco89
    Nik
    Charlotte, NC
    So just go with the 1/4" spacer? I want to fit 285/70/17
  15. Apr 12, 2011 at 8:48 PM
    KPT
    09 Prerunner
    Plenty of people have fit that size with no spacer at all.
  16. Apr 12, 2011 at 8:49 PM
    Taco89
    Nik
    Charlotte, NC
    Alright cool, what if I set my bilsteins to 1.75 with the 3/4?
  17. Apr 12, 2011 at 8:52 PM
    KPT
    09 Prerunner
    What would make you want to do that over just setting them at 2.5"?
    Toplate spacers in general are bad news....all they do is force the whole suspension downward...they can make your bump stops useless (i.e. the shock will bottom out before you hit the bump stops), and will give you too much down-travel, causing your ball joints to bind.
  18. Apr 12, 2011 at 8:58 PM
    Taco89
    Nik
    Charlotte, NC
    I like the lift size that I have now, if I just get new UCA's will that be safe?
  19. Apr 12, 2011 at 8:59 PM
    OZ-T
    Peter North
    British Columbia
    Hard on your truck that is .
    I missed the thickness of your spacer on first pass , you need to come down to 3" and get UCA's
  20. Apr 12, 2011 at 8:59 PM
    KPT
    09 Prerunner
    Absolutely not. nothing over 3" is good for the truck....
    Think of how an IFs works. By lifting the truck 4" total, you have rotated the LCA downward 4"...the spindle length obviously can't change, so the slack is taken up by the ball joint in the uca being at an extreme angle, even with all 4 wheels on the ground. When you go over a bump and the suspension moves downward, it will get even worse.
    If you wanted a 4" lift you should have bought spindles.
