Bilstein 5100
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Loretta, Sep 27, 2020.
  1. Oct 20, 2020 at 7:55 PM
    Pirate1975
    Pirate1975 “What do you do with a drunken sailor...?”
    Steven
    Statesville, NC
    2017 Silver TRD Off-road
    3rd bedrail.32”duratrac tires.CaliRaised bed stiffeners,rear ditch bracket for cb antenna .SOS Concepts sliders,3skids,bedrails.curtis rack.cobra 75 cb.HAM license.887 coils,Bilstein 5100’s,medium Dakar leaf pack,extended rear brake lines,wheeler’s superbumps bumpstops.carrier bearing drop bracket.sway bar delete
    OME will be more softer ride as is a different type of shock as bilsteins. They will give you a much better ride on washboard roads!!
    Bilsteins will be stiffer as more of a rebound type shock..will be stiffer on washboards..
    @HeadStrong Off-Road is where I bought my suspension.
    You can get a complete kit. Bilsteins with 886 coils will be good for added steel bumper or winch. You can get the heavy leaf springs if you are running a tent. If you need heavier then you can still add a leaf or airbags.
    I didn’t have a tent or steel bumper, but I still added wheeler’s bump stops..
    If washboard roads, then a complete OME with 886 coils and heavy leafs would be good and you can still go over rocks as well..
  2. Oct 20, 2020 at 9:08 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    They may or may not give you a softer ride which is a matter of opinion, but ome springs will sag which is a fact.b It's a known issue, also headstrong knows this!
    71tattooguy likes this.
