Bilstein 5100
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoSupreme96, May 27, 2023.
  1. May 27, 2023 at 8:48 PM
    TacoSupreme96
    TacoSupreme96 [OP] Active Member
    2023 Tacoma TRD Sport
    I’m installing Bilstein 5100s, if I max them out at 2” will it still ride good?
  2. May 27, 2023 at 9:52 PM
    Silverlogic
    Silverlogic Well-Known Member
    Tyler
    San Diego, California
    2018 Silver DCSB TRDOR
    Probably not.
    Rusty66 and Chew like this.
  3. May 27, 2023 at 10:27 PM
    tombiosis
    tombiosis Well-Known Member
    T
    Ottawa Canada
    2016 TRD offroad access
    2016 Tacoma Access Cab, Super White, TRD Off Road package,//OEM Running Boards//TriFold2.0 Tonneau Cover//FJ Cruiser TRD SE Black TrailTeams replca wheels!
    I just installed a set of 5100’s all around…
    I used position 2 for the front, getting.65” of lift, nothing in the rear except the new billies. Rides good, a bit stiff for now, but I wanted new shocks. Truck looks more level now. Its a 2016 trd or access cab.
  4. May 27, 2023 at 10:32 PM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    I have them all around. Truck leveled. Rides better off road, slightly rougher over the road, but NOT negatively so.
  5. May 28, 2023 at 6:02 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Your ride prospective will depend on where you started off from. You are starting from the TRD Sport shocks, so Bilstein's will feel a little softer and more controlled on rebound.
    I went with Eibach Pro-Truck Stage 2 Coilovers from TRD Sport Hitachi's. They are similar to the Bilstein's, the ride is still firm but not jarring after hitting the first bump like the stock shocks. I felt it was a huge increase in ride quality and comfort. And control over uneven road surfaces improved.
    Off-Road's have softer shocks stock so they will have a stiffer shock moving to Bilstein's.
    MQQSE and airforceb2cc like this.
  6. May 28, 2023 at 11:50 AM
    Claudiomartinof
    Claudiomartinof Well-Known Member
    2019 TRD OFF ROAD 6MT
    I am at 2” front and it rides ok. Stiff… yes… less body roll than stock bilsteins… I like it.
    MQQSE likes this.
  7. May 28, 2023 at 1:11 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Big improvement immediately, losing the OEM brake dive. Just a bigger, better shock. If you have a access cab, you're not supposed to use the top notch.
  8. May 28, 2023 at 1:13 PM
    Claudiomartinof
    Why can’t use top notch on access cab?
  9. May 28, 2023 at 1:14 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    andthen likes this.
  10. May 28, 2023 at 1:16 PM
    Claudiomartinof
    but what is the argument behind it?
  11. May 28, 2023 at 1:19 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Sorry, I have no idea, I own a 4 door. Maybe someone else can chime in.
  12. May 28, 2023 at 1:19 PM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    I'd guess it goes above leveling the truck. I'm sure there must be math involved related to wheelbase and weight distribution. :notsure:
  13. May 28, 2023 at 3:14 PM
    Claudiomartinof
    Yes… probably it would go higher due to less weight..
