Bilstein 5100's @ 1.75 - AAL & UCA input needed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ycart1201, Apr 28, 2016.
  1. Apr 28, 2016 at 8:15 PM
    ycart1201
    ycart1201 [OP] Well-Known Member
    Nathan
    Oregon
    2016 DC TRD Sport 4x4 - My build is underway
    Current Project: 2016 DC TRD Sport 4x4
    This question is for those of you with Bilstein 5100's set at 1.75 w/ stock coils on your 2016 Tacoma.
    (FYI: I've read & read & read... and searched and still have questions so please don't flame me).
    I'd like to use Add-a-leafs to lift the rear with the front at the 1.75 setting (I'll have 5100's on the rear too).
    -What brand AAL did you use?
    -How much did it lift it (essentially are you bro-lean, level, or raked?)
    I'd like it to be level or slightly raked (nothing more than stock though).
    -Any pics showing your truck from the side so I can see how the rear sits compared to the front?
    Next Question:
    Did you have to replace the UCA's to get back to factory alignment specs at the 1.75" setting? I understand the 2016 sits 1" higher, so essentially I'd be 2.75" over gen 2 tacos. This has me thinking I'd need new UCA's, but would like to know for sure from someone who has ran this setup.
    PS: Not that it matters but I'll be running 275/75-17 tires.
    Thanks in advance!
    Nathan
    ycart1201
    619HiluxLover likes this.
  2. Apr 29, 2016 at 1:55 AM
    xTacoma16x
    xTacoma16x Well-Known Member
    TRD sport 2016
    When 3rd gen comes with 1" lift with factory alignment set at zero, that means they don't mess with alignment to set at factory specs to compensate for 1" lift. 1.75" lift on 3rd gen is 1.75 lift. You should be fine with stock ucas.
    619HiluxLover and ycart1201[OP] like this.
  3. Apr 29, 2016 at 8:21 PM
    ycart1201
    Nathan
    Oregon
    Thanks xTacoma16x for input on the ucas. ;)
    Anybody else have thoughts? Would really love to know what you guys are using to lift the rear when you're billys are set at 1.75.
    Thanks,
    Nathan
    ycart1201
  4. Apr 29, 2016 at 8:35 PM
    Js16taco
    Js16taco Well-Known Member
    2016 Tacoma trd sport
    And not to thread jack.. But if when you get it on the 5100's post pics! I have 275/70 on mine as well and was looking at getting billies set to 1.75 as well
  5. Apr 30, 2016 at 7:32 AM
    ycart1201
    Nathan
    Oregon
    Will do Js16taco.
    I've been researching a lot on this site about this set up and have gotten many different results. Here are examples of what I've read:
    @.85 + no rear lift = level
    @1.75 + no rear lift = level
    @1.75 + 1" block in rear = level
    I've even read that one member had his front oem coils start sagging with this set up.
    With all the mixed setups that supposedly = level I'm not sure what to buy. Especially since I was leaning towards AALs for the rear (not blocks). If no one chimes in, I may just have to get the front done and measure it, then buy a rear set up and pay for the rear install separately. :annoyed:
    Anyone with 1.75 setting want to chime in...? :fingerscrossed:
  6. Apr 30, 2016 at 1:19 PM
    PBBOUND
    PBBOUND Well-Known Member
    Brian
    Gilbert, Az.
    `16 Silver Tacoma SR5 DCSB V6
    Set at 1.75 with stock springs and nothing on the rear. These were about 10 days ago and it has settled to almost level. I like the small reverse rake. Drives xlnt with no issues so far. 265/70/17taco5.jpg taco5.jpg
    geno0506, sdhendo31 and 2000man like this.
  7. Apr 30, 2016 at 2:31 PM
    JoeRacer302
    JoeRacer302 Well-Known Member
    Joe
    Pasadena, CA
    2016 DCSB OR MT Inferno
    Front: 5100's @ 0.85 Rear: 1/2" spacers 265/75r16 on RAY10
    Should throw some sand bags in the back and get more of that bro-lean...
  8. Apr 30, 2016 at 2:35 PM
    2000man
    2000man The Church Of @ODNAREM San Diego Chapter 1904
    G
    SDMF CA
    Shadow 4x4
    Great looking Taco! Keep us up updated if the front starts to sag Thanks!
  9. Apr 30, 2016 at 3:16 PM
    PBBOUND
    Brian
    Gilbert, Az.
    Today
    619HiluxLover and sdhendo31 like this.
  10. Apr 30, 2016 at 3:22 PM
    2000man
    G
    SDMF CA
    Shadow 4x4
    Front came down a little huh? Alignment is ok? Thanks!
  11. Apr 30, 2016 at 3:25 PM
    PBBOUND
    Brian
    Gilbert, Az.
    Yeah. Alignment is perfect so far. What part of SD? I lived in PB and hope to return someday when I can afford it.
    sdhendo31 likes this.
  12. Apr 30, 2016 at 3:56 PM
    ycart1201
    Nathan
    Oregon
    Awesome! This is EXACTLY the type of info I was looking for!!! :thumbsup::thumbsup::thumbsup:
    Did you happen to take before and after measurements from the center of the wheel to the bottom of the fender?
    Thanks again!!!
    Nathan
    ycart1201
  13. Apr 30, 2016 at 6:08 PM
    2000man
    G
    SDMF CA
    Shadow 4x4
    Right now I stay in Santuckey or (Santee) I love PB and used to stay OB, save up a lot cuz cost of living has gone up!
  14. Apr 30, 2016 at 6:41 PM
    PBBOUND
    Brian
    Gilbert, Az.
    I didn`t. Just knew I wanted the nose either level or reversed. I did a lot of reading on here also before I decided on 1.75 and decided I could live with a little pre-runner rake vs. having to reset them from .85 down the road
  15. May 1, 2016 at 10:53 PM
    treehugger
    treehugger Well-Known Member
    Oregon
    2016 Tacoma TRD OR DC 4x4
    265/75/16 BFG AT2 Bilstein 5100 @ 1.75
    I'm running them at 1.75 with a 1.5" block in the back. It left me with a little bit of rake which is what I was going for. Note I keep about 150lbs of gear all the time so it squats it about 1/2".
  16. May 2, 2016 at 4:59 PM
    ycart1201
    Nathan
    Oregon
    More great info! :thumbsup: Thanks for posting.
    Seems like a block in the back may be the direction I need to go.
    Thanks,
    Nathan
    ycart1201
  17. May 15, 2016 at 10:12 AM
    Rb1
    Rb1 Well-Known Member
    Ron
    Kent Wa
    2016 tacoma trd offroad dc
    Anyone running headstrong aal without the overload. They say 1.5 on that setup. Or i was thinking sumo spring. Just not sure what i want to do with the rear. I know i want the front set at 1.75. I eventually will have a canopy, so i expect that to cause a 1/2 inch squat. I also would like to end up with around a 1 inch or less rake. Kinda thinking I'd start out at 1.75 with sumos. Then add headstrong later if needed.
  18. May 27, 2016 at 11:53 PM
    sdhendo31
    sdhendo31 Active Member
    North County San Diego
    - 2004 titan prerunner - 2016 BBP DCSB OR 4x4
    Prerunner mid travel kit with rear bed cage.
    Pbbound... That's just with the 5100 billys that have the adjustable spring perch set at 1.75"? Are they the 2006-2015 5100 billys?
  19. May 28, 2016 at 6:33 AM
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
    Great looking truck! I think i saw you driving south on val vista yesterday around 6ish.
    This is also the look i would want to go for. Thanks for the info!
  20. May 28, 2016 at 7:10 AM
    donny.brooke
    donny.brooke Well-Known Member
    Kelowna B.C. Canada
    2019 TRD Offroad
    With the fronts at 1.75 you will need new upper control arms to get the alignment specs proper.
