Bilstein 5100's @.85 any vibrations ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hot2na, Aug 17, 2013.
  1. Aug 17, 2013 at 7:54 AM
    Hot2na
    Hot2na [OP] Well-Known Member
    Thinking of 5100's...gonna set @.85...only want a slight leveling effect in the front...
    Was wodering if anyone here experienced driveline vibrations after installing them and setting @ .85.....
    and if so....is there an easy fix ????
    thanks...
  2. Aug 17, 2013 at 9:08 AM
    Derfus
    Derfus Active Member
    Installed mine yesterday at .85 and no vibes that I can tell. I did figure out that my ride is MUCH better than the stock bilstein shocks with 120k on them. If your rear leafs are as flat as mine are you might need an aal to get it level. I still can't decide if mine has a nose up lean.
    Edit: aal on mine right now would put some rake back in it but I'd rather have a little rear rake than a bro lean.
  3. Aug 17, 2013 at 12:11 PM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    Great question. That is what I am getting ready to do. Good to hear that we don't have to worry about any vibs. Thanks for posting .:)
  4. Aug 17, 2013 at 1:26 PM
    bobbybreach
    bobbybreach Well-Known Member
    bobby
    westchester NY
    09 TRD
    Mine are at 1.75" and no vibs or anything. Rides 10x better then stock
  5. Aug 17, 2013 at 1:27 PM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    From what I've read on this forum, your good to go as long as you don't go higher then a 3" lift. Any higher than that and it changes the orientation of your drive-line resulting in diff drops and shims for other drive-line components. 55 MPH seems to be the speed when the sun and stars aline for vibrations.
    -J
  6. Aug 18, 2013 at 4:00 AM
    Hot2na
    forgot to add ...my 2012 has the 4 leaf rear springs from the factory
  7. Aug 18, 2013 at 7:35 AM
    tacoma guy
    Joe
    Phoenix Az.
    Did you use your stock coil springs and if so which ones are they ? The TRD off road or sport ?
  8. Aug 18, 2013 at 8:41 AM
    Derfus
    Yep. Stock springs and its a sport.
  9. Aug 18, 2013 at 8:50 AM
    tacoma guy
    Joe
    Phoenix Az.
    Ok great . Thanks for the info !!!
