Bilstein 5100's and OME 885 coils?
Discussion in 'Suspension' started by Taco4x4NC, Mar 9, 2010.
  1. Mar 9, 2010 at 4:33 AM
    Taco4x4NC
    Taco4x4NC [OP] Well-Known Member
    David
    Western North Carolina
    2010 4x4 DC/LB "Pytrite Mica/Katzkin leather
    3m clear bra or Venture, stant locking gas cap, Shield, front windows tinted, weathertechs, ARE "Z" topper. Sockmonkey decal, Billy 5100's x 4 corners, Eibach coils, Toytec 1.5 AAL. Michelin 265/75/16 MS2's, Grillcraft MX series/TOYOTA badging. FJ/SE TRD Anthracite gray wheels. Katzkin leather/heated seats.
    I already have the Billy 5100's arriving this week sometime. Got to thinking that I may just upgrade the coils while I am at it. Plan to add the 1/4 spacer to eliminate the taco lean as well. thoughts on this?
    Suggestions on the best coil and 5100 combo? I would like to achieve a decent lift, but maintain a decent ride. Anyone running the 885's with Bilstein 5100's? infor appreciated.
    thanks in advance-
    Taco4x4nc
  2. Mar 9, 2010 at 8:23 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    There are alot of guys on here running the 885's with 5100's!
  3. Mar 9, 2010 at 8:26 AM
    jason1kyle
    jason1kyle commander101
    JOHNSON CITY, TN
    08 double cab trd sr5
    77 series k&n 1inch throttle body spacer dual in single out catback exhaust (exhaust pros)
    i thought u couldnt run the 5100's with the 885's only the 884 or 883 i think thats what it says on toytec website
  4. Mar 9, 2010 at 8:30 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Well you can and thats what I am running are the 885's with the 5100's. You have to leave the 5100's at the stock height setting since the coils will be doing the lift. I would suggest going with the 886's if you are the long bed though.:cool:
  5. Mar 9, 2010 at 8:11 PM
    ryber
    ryber Well-Known Member
    kitchener, ontario
    06 Reg Cab 4X4
    285/75/16 MTZ's.... OME lift(885s)...4:88 gears.... Front and rear ARB.... Homemade skids
    Are you running a spacer with that as well like everyone elese seems to be doing or just the 5100 and 885.. Just wondering what height you get without a spacer.
    I just ordered 885s for my 5100s and wondering if I should get spacers as well.
  6. Mar 10, 2010 at 7:10 AM
    jason1kyle
    JOHNSON CITY, TN
    ok but with the 884 u can set the 5100's at .85 heard of alot of guys doin that
    and how the ride with the 885's wanted them and did u only get 2" outa them??
  7. Mar 10, 2010 at 7:14 AM
    elliott.estes
    elliott.estes Well-Known Member
    sacramento
    07 Black DC TRD Sport
    In Dash Avic-D3 / Blacked out headlights / Satoshi Grille / OME 90000 Front Shocks/ OME n182 Rear Shocks / OME 885 Coils / AAL with TSB's / 10MM lift Enhancer Kit / Light Racing UCA's / BFG AT KO's (285x70x17's) / Procomp 7089 Rims
    that's a good setup!
  8. Mar 10, 2010 at 1:15 PM
    Taco4x4NC
    David
    Will run with the Toytec/Eibach coils and the 5100's set at .85. Should prove to be exactly what I am after. I am hoping to stay under the radar an not have to have UCA's for caster and camber.
    Also ordered the 1/4" spacer to remove the Tacoma lean. Figured might as well add it while I am having the work done. Thanks to Jen for her help today with my order.:)
  9. Mar 10, 2010 at 1:19 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    i have 885 w/ 5100 at 0, with 1/2 inch spacer... to get a full 3" i needed the spacer
  10. Mar 10, 2010 at 1:24 PM
    619Tacoma
    619Tacoma Baja bound
    Call me Rocco
    San Diego, CA
    07 PreRunner SR5, Sport, 4dr
    - Billstein 5100's all around with OME 885 coil springs. - K&N Air Filter - HID Headlights & Fogs - Kenwood Stereo & Infinity Speakers - CB Radio, - Fog On Anytime mod - Anti Tailgate theft mod. More comming...
    I'm also running 885's with 5100's.. Ive had the setup for about 3 weeks and i'm overall happy with it. It did good off road.
    No spacer though. I just set the 5100's at 0" and got close to 3" of lift.
  11. Mar 11, 2010 at 7:48 AM
    jason1kyle
    JOHNSON CITY, TN
    awesome well looks like i'm getting the 885's now lol thanks guys
  12. Mar 11, 2010 at 8:24 AM
    geolink
    geolink Well-Known Member
    SILVER STATE
    09 DCLB MagGray TRD SPORT
    Weathertech mats and hood protector, RuffTuff seat covers, padded console, Redline Hood Struts, Snugtop canopy w/Thule Rack, TSB rear springs plus AAL, 5100's all around OME 885 front coils, LR UCA, Avid Step Bars, LT265/70R17 BFG AT on stock Sport Rims
    Ditto, that is my setup for 6 mos now and real pleased with the lift/ride on DCLB. Included LR UCA's for alignment ease.
  13. Mar 11, 2010 at 10:16 AM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    I've got 5100's set at stock height with 885 coils plus a 13mm spacer on both sides and an extra 1/4" on the drivers side. It rides a little rough but its much better then the 5100's set at 2.5". In retrospect I wish i went with all OME stuff right from the beginning
  14. Mar 16, 2010 at 1:04 PM
    Hunter'06FLKY
    Hunter'06FLKY Well-Known Member
    Central Florida
    08 Access Cab SR5 4x4
    Bilstein 5100's on all 4 corners, OME 884's, Toyotec AAL, Differential Breather, PIAA Fog's, K & N Air Filter, Definity Dakota M/T's, Cherry Bomb Extreme High Clearance
    Can you run the 885 coils with the stock uca's? I've heard mixed input on this. This is the setup I am planning on doing within the next couple of weeks and want to make sure it'll work ok.
  15. Mar 16, 2010 at 1:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You can, but your alignment wont be in spec.
    tcBob and llamasmurf like this.
  16. Mar 16, 2010 at 2:01 PM
    Hunter'06FLKY
    Central Florida
    thanks chris.
    does anyone here run them without new uca's? any input or thoughts on it otherwise?
  17. Mar 16, 2010 at 2:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It could be your roads are better? Im sure your Caster is below 1*.
  18. Mar 16, 2010 at 2:51 PM
    98tacoma27
    Ben
    Not Beech Creek
    :rofl:
    :rofl:
    BWHAHAHAHAHAHAHAHAHAHAHAHAHAHAAHAHAHAHAH!!!!!!!!!!!!!!!!!!!!!!!!!!
  19. Mar 16, 2010 at 2:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    HEY! ...They could be......
  20. Mar 16, 2010 at 2:56 PM
    98tacoma27
    Ben
    Not Beech Creek
