Bilstein 5100's and OME 885 coils?
Discussion in 'Suspension' started by Taco4x4NC, Mar 9, 2010.
  1. Mar 16, 2010 at 3:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  2. Mar 16, 2010 at 4:08 PM
    98tacoma27
    Ben
    Not Beech Creek
    Every year at this time, PENDOT displays their large collection of orange barrels along Pensylvania's roadway to commerate the new construction season.
    Lasts clear until November
  3. Jan 13, 2012 at 8:33 AM
    dwsalley95
    dwsalley95 Well-Known Member
    Dylan
    Columbia
    07 TRD SPORT
    Is your truck a long bed?? Also, did you have your billies set at anything other than 0' before the coils?? I have front billies set at 1.75 and want to order 885's, will I be able to set them back to 0'?
  4. Jan 14, 2012 at 1:40 PM
    1FSTLS1
    1FSTLS1 Well-Known Member
    Can any one explain why changing the coils vs just setting the shock at 1.75 or 2.5 is better. I have the 5100s and trying to do some more research before I put them on. My truck is a daily driver now but wont be in March.
  5. Jan 14, 2012 at 1:57 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    You need to understand the difference between a pre-load lift and a spring lift.
    Either read some more or maybe someone can explain.
  6. Jan 21, 2017 at 11:05 AM
    OR tacoma
    OR tacoma New Member
    2011 4x4 TRD Off road
    I've ordered a set of OME 2885's and Bilstein 5100's for both the front and rear. I put a winch and grill guard on last year which dropped the front end about an inch. So I'm wondering what's the highest setting I can put the front 5100's at before I start having UCA and CV joint issues? I'm thinking the 1" setting to cancel out the winch & grill guard and the springs will bring the front up another 2 1/2"? That sounds like I shouldn't have and alignment spec problems. Also I thought OME springs came labeled left vs. right to account for the lean everyone keeps mentioning?
    Anyway, obviously not planning on a diff drop kit or add a leaf at this point.
  7. Mar 30, 2017 at 10:45 AM
    Superduner
    Superduner Member
    Jose
    Would you guys recommend doing a diff drop kit for the 5100/885 coil set up? I'd probably not run the additional spacer as my 07 DCLB is all stock and ha do additional weight other than a fiberglass camper shell. And what rear lift kit or set up would you guys recommend to balance out the rear lift height /level wise. I don't tow anything other than a sports quad in the bed.
