bilstein 5100s and what ome coils??
Discussion in 'Suspension' started by gracianoh, Jul 6, 2018.
  1. Jul 6, 2018 at 8:23 AM
    gracianoh
    gracianoh [OP] Well-Known Member
    06 1e7 access cab 4x4
    so ive had an 06 Tacoma access cab before and had Bilstein 5100s with 886x ome coils because I had a front steel bumper and winch and all that. ive since sold the Tacoma (which was one of the best trucks ive owned) A friend of mine has a 2011 Tacoma double cab. I told him go with the Bilstein 5100s but not sure which OME COILS to go with since his is double cab and will not have any bumpers added. he is wanting to achieve the highest he can up front without having to replaced upper control arms. He is wanting to go 3" lift up front but if I remember right that will need upper control arms to correct the alignment. so maybe 2.5"? plus does that year also have the taco lean?
  2. Jul 6, 2018 at 8:28 AM
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    He'll want 885's which will net him 2.5" and yes he will need the 1/4" top plate spacer to compensate for the taco lean. It's a toss up at 2.5" on whether he'll need UCA's. I put them on for piece of mind. I haven't driven a taco without UCAs and 885 coils installed so I can't compare the rides.
    LocoLocal likes this.
  3. Jul 6, 2018 at 8:51 AM
    gracianoh
    On the 5100s leave the notch at 0 right ?
  4. Jul 6, 2018 at 8:52 AM
    doorsidedown
    doorsidedown Well-Known Member
    Yep
  5. Jul 6, 2018 at 8:55 AM
    gracianoh
    I remember my setup was the 5100s and 886 with taco lean spacer and at full droop it would hit the control arms. He isn't gonna fo any off roading so no issue there with full droop
