Bilstein 5100s lift
Discussion in 'Suspension' started by BlueberryTaco18, Dec 2, 2020.
  1. Dec 2, 2020 at 2:16 PM
    BlueberryTaco18
    BlueberryTaco18 [OP] Member
    Noah
    2016 Blue 4 by 4 TRD Offroad Tacoma
    I don't know much about suspensions but I am looking to get around a 2 inch lift in the front and am thinking about bilstein 5100s and have a question about getting new coils. Do coils lift the truck at all or is that just the adjustable struts. I saw a guy on youtube say he set the bilstein 5100s to the first notch but added 2.5" coils and got a 2.5" lift in the front. Can anyone clear my confusion up.
  2. Dec 2, 2020 at 6:24 PM
    Tacoma13_NC
    Tacoma13_NC Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; BFG KO2's (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT)
    5100 front struts can lift the front using factory coils, but start to compress the coil the more you adjust the height upwards. Lifting coils will lift the truck and allow the 5100 struts to remain on the lowest setting for the best overall ride and performance. It just depends on how much you want to lift and what you're plans are for the rear.
  3. Dec 2, 2020 at 6:55 PM
    Marcmtb1
    Marcmtb1 Well-Known Member
    PHX, USA
    2016 Tacoma TRD OR DCSB 4x4
    5100/885 w/ 1/4 lean spacer, Icon RXT w/ B110’s, 255/80/17 FWP, AP Apex Sliders, KDMax 87, ADD W1, BD mirror riser
    Blistein 5100s set for 0” lift are paired with OME lift coils by many in TacomaWorld because you can get the lift via longer coil, maintaining OEM spring rate and avoid the increased spring rate from cranking down the OEM springs.
    Jukeboxx13 likes this.
  4. Dec 2, 2020 at 8:59 PM
    BlueberryTaco18
    Noah
    Thanks guys! I think I’ll get the bilsteins, put them at the lowest setting, get a 2 inch OME spring, and a 1.5 add a leaf in the rear? Anything wrong with that?
    Marcmtb1 and Tacoma13_NC like this.
  5. Dec 3, 2020 at 11:08 AM
    Marcmtb1
    PHX, USA
    If you have the cash, get a new leaf pack for the rear. I have the Icon RXT and it was the best $700 I’ve ever put into one of my trucks. There are a lot of other options out there too.
  6. Dec 4, 2020 at 3:16 PM
    MNYota
    MNYota Member
    David
    Minnesota
    2001 Toyota 4Runner SR5, 2010 Tacoma SR5 Sport
    Work in progress
    2010 Tacoma 4x4 access cab here, bone stock. Total daily driver. Will the 5100’s alone let me clear 285’s on stock rims without rubbing?
    If not, what would be the best “bang for my buck” to make this work? I want the on-road ride to be as good if not a little better. And, I don’t want to have to mess with UCA’s, longer brake lines, etc.
  7. Dec 4, 2020 at 6:42 PM
    6Thick
    6Thick Well-Known Member
    Poconos
    2015 TRD Sport MGM 6MT
    TRD Pro Rims, BFKO2 265/70/17, ARE Shell, Leveling kit
    Dude!?
  8. Dec 4, 2020 at 7:02 PM
    Tacoma13_NC
    Stick with 265's if you don't want to mess with chopping, trimming, and UCA's.
  9. Dec 5, 2020 at 6:34 AM
    MNYota
    MNYota Member
    David
    Minnesota
    Work in progress
    I can’t decide if this reply was helpful or hurtful. There’s so much good info there, I’m leaning toward helpful.......
  10. Dec 7, 2020 at 10:36 PM
    Jukeboxx13
    Jukeboxx13 Well-Known Member
    California
    2017 TRD OR DCSB 4x4
    exactly what im doing. 5100s with ome 887 coils and a single aal in the rear for a nice 2/1 lift. Cant wait for the firmer ride to better handle what I haul.
  11. Dec 7, 2020 at 10:38 PM
    Jukeboxx13
    California
    It should clear but every trucks different. Just the other day I read about two exact trucks with the exact 285s, and one runbed while the other didn't. Only one way to find out forsure.
