Bilstein 5100s, OME 887s
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Travis1209, Sep 13, 2017.
  1. Sep 13, 2017 at 1:05 PM
    Travis1209
    Travis1209 [OP] Well-Known Member
    Travis
    2011 TRD Offroad Double Cab SB
    So im hearing mixed comments on whether or not its okay to run Bilstein 5100s with OME coils at the .85" setting? I know the recommendation is to always keep this setup at 0", but how many of you run them at .85"?
    Curious about setting mine from 0 to .85 to get a slight amount if lift instead of ordering top plate spacers.
  2. Sep 13, 2017 at 3:07 PM
    Friedtacolover
    Friedtacolover Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
    Ive done alot of research decided to go 4" maxtrac spindles with a rear 3" leaf. I was considering 887's. From what ive read as long as you have uca's the .85 is ok. Not recoomended option but will work. The 887 should give u 2.5-3" of lift at zero
  3. Sep 13, 2017 at 3:11 PM
    Travis1209
    Travis
    I have them right now set at 0", thanks for the reply
  4. Sep 13, 2017 at 3:15 PM
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    If you are 4x4, you need to be mindful of your CV angles. 3in is the recommended max before you start putting wear on the boots. If you have the boot fins already touching, I wouldn't mess with adding any more lift.
  5. Sep 13, 2017 at 3:18 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    My 887's have me just at 3 inches I don't know what you attained with yours but I wouldn't add anything on top of the but the 1/4 driver's spacer, and definitely wouldn't go up to .85 either.
    Travis1209[OP] and Chase8059 like this.
  6. Oct 12, 2017 at 8:02 AM
    Travis1209
    Travis
    Yea im probably right at 3", my CV boots are just about maxed out from rubbing so its going to stay where its at
