Bilstein 5100s on 19 TRD Offroad
Discussion in 'Suspension' started by Joshua98, May 22, 2019.
  1. May 22, 2019 at 2:46 PM
    Joshua98
    Joshua98 [OP] Member
    Joshua
    2019 TRD Off-road
    None
    What does everyone think about doing 5100 adjustables just on the front and leaving rear completely stock except for bigger tires on all 4 corners? Read that only difference between 5100s and stock bilsteins on my tacoma is the 5100s have slightly different valving for bigger tires. Is it worth replacing the rear as well considering rear 5100s provide no lift? Also what form of rear lift do you reccomend? Block kit or add a leaf? Thanks!
  2. May 22, 2019 at 7:51 PM
    Jblud1986
    Jblud1986 Well-Known Member
    Middleburg, FL
    TRD Off-Road 4x4
    Bilstein 6110 650# coils 3 leaf add-a-leaf in rear SCS Ray 10s -38 with bronze finish 35/12.5 MT Baja Boss ATs JBA Off road UCA's Diode dynamics lights Relentless Fab hybrid bumper CBI sliders
    I would replace your stock shocks in the rear if adding a lift and I would go a progressive 3 leaf AAL. Bypass the block kit
    Joshua98[OP] likes this.
