Bilstein 5100s on 2nd notch with OME 888 coils: is a cab mount chop necessary to fit 16x8 -25?
Discussion in 'Suspension' started by AnotherFilipinoTacoOwner, Aug 12, 2021.
  1. Aug 12, 2021 at 12:35 AM
    AnotherFilipinoTacoOwner [OP] New Member
    2021 TRD OR 4x4
    Hey all, I’m a new TRD OR 4x4 owner. Wasn’t exactly sure if this is a suspension or wheel/tire question.
    I bought a set of SCS F5s in 16x8 -25 before I bought a lift, because I thought they were cool (and I thought offset wouldn’t matter too much since it’s a truck).
    I ended up buying my 5100s on the second notch with the OME 888 coils the next day, because I’m eager to get these wheels on.
    I’m planning on running either a 265/75/16 or 255/75/16. I’m down to get a cmc, but I just want to know if it’s necessary so I can get it done before I get tires for the wheels.
    Also, any other tire size recommendations are welcome. I don’t care too much about 33’s since it’s primarily a daily driver.
    PhotoDan likes this.
  2. Aug 12, 2021 at 4:47 AM
    PhotoDan
    PhotoDan Well-Known Member
    Dan
    SoCal
    2019 TRD Off-Road DCSB 4x4
    ORA Front Bumper ORA Rock Sliders ORA Tire Carrier Bilstein 5100s front and rear OME 888 Deaver AAL SPC UCA 35" Ridge Grapplers
    With 265/75r16 and -25 offset wheels, you will need to remove mud flaps and use a heat gun to push your fender liners back near the cab mount.
    I don't have experience with 255/75r16, so I can't help with those tires.
  3. Aug 13, 2021 at 6:29 AM
    TNFishyTaco
    TNFishyTaco Well-Known Member
    Cory
    I’ve got these same wheels and tires. I’ve removed mud flaps and and bent plastic and still get a slight rub on full lockout. I’ll be lifting using this same lift. In order to get a more level look, should you do new leaf springs as well?
  4. Aug 14, 2021 at 1:43 AM
    2021 TRD OR 4x4
    You’re running this on stock suspension? What trim level do you have?
  5. Aug 14, 2021 at 8:38 AM
    TNFishyTaco
    Cory
    ‘14 TRD off road. I removed the mudflaps and just bent some of the inside fender well with a heat gun from harbor freight. Still a slight rub in certain situations. I could have bent/cut more but I’m just going to lift instead.
