Bilstein 5100s or 5125s with Dakar Leafs?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Snowman, Nov 26, 2010.
  1. Nov 26, 2010 at 10:05 AM
    Snowman
    Snowman [OP] I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Which would be the better choice to go with OME Dakars, the 5100s or 5125s? Everywhere says the 5100s are good for up to 2" lift and the 5125s are good for 3"+. The Dakars are supposed to be a 2.25" lift so they seem to be inbetween. Anyone running Bilsteins with Dakars?
  2. Nov 26, 2010 at 7:29 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    5125s are not a single size, I think there are 3 basic lengths. They are sized by extended and compressed lengths.
    To be really accurate you should know the distance from eye to eye when extended and compressed. To further complicate, those numbers will be different on the driver side compared to the passenger side.
    The tech folks who sell Dakars should be able to give you more accurate advice on which 5125 model to get.
  3. Nov 27, 2010 at 10:13 AM
    JDBECK23
    JDBECK23 Well-Known Member
    Jesse
    King George, Va
    '01 Tacoma Reg Cab 4 cyl 4x4
    My understanding is that the rear 5100's are made for a lifted truck up to 3 inches of lift. The 5125's are made for a stock ride height in the rear. Correct me if someone has personal information though.
  4. Nov 27, 2010 at 10:54 AM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    I was talking to DSM and they said the 5125 are for longer applications. I think the 5100s will work with the 2.25" dakars, but they are probably going to be at the end of their range. Someone must be running Billys with their Dakars that can share their knowledge!
  5. Nov 27, 2010 at 11:06 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    have you thought about using the OMEN182s they are designed to run with the dakar springs...
  6. Nov 27, 2010 at 11:10 AM
    ERIC
    ERIC Well-Known Member
    Eric
    Orange County, CA
    2002 Impulse Red TRD PreRunner SOLD
    Pioneer double din navi head unit and four 5x7 alpine speakers, westin light bar, procomp lights, head and tail lights, black billet grille, billet antienna, gibson headers and cat back exhaust, afe cold air, uni chip programmer, Bilstein 5100's, Pro comp wheels and tires, tint, blacked out emblems, innu roof rack, yakima basket, foglight mod...
    jdbeck23 is right. i have 5125's in the rear with stock leaf springs, if u wanna raise it up with taller leafs go with 5100's
  7. Nov 27, 2010 at 11:13 AM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    I have and I may go with them. I am just trying to save a few $$ by using Billys instead of OME.
  8. Nov 27, 2010 at 5:19 PM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
  9. Nov 27, 2010 at 7:33 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    Thats what DSM said when I emailed them. They didnt say yes or no to the 5100s, but I got the impression that they would work, though arent necessarily the best choice.
    So the question is, how do I calculate the correct length to order? I cant really install and measure some Dakars then run them without shocks for a few weeks while I wait for stuff to arrive.
    Would I just get a set that are 2-2.5" longer than stock length?
  10. Nov 27, 2010 at 7:46 PM
    Yoytoda
    Roland
    completely stock
    even if they are 3" longer if will give you better flex offroad. 3" longer are fine... even when ordering they say up to 3" of lift so 2.5" is fine
  11. Nov 27, 2010 at 8:04 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    So I read on CT (via google) that stock rear travel is 6" & 6.5". So one 5125 at 8.6" of travel and one at 9.24" should work with the 2.25" lift? That would give an additional 2.6" and 2.74" travel respectively.
    Does that make sense? Can anyone confirm the stock rear travel?
  12. Nov 27, 2010 at 8:09 PM
    Yoytoda
    Roland
    completely stock
    that would make sense, just makes sure the overall length is only 3" longer
  13. Nov 27, 2010 at 8:10 PM
    Ridingontrd
    Richard
    Laughlin,N.V
    :thumbsup:
  14. Nov 27, 2010 at 8:21 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    Yeah, I just cant seem to find overall length listed anywhere. The link to DSM posted earlier only has "shock travel", "extended length" and "collapsed length". Since they are custom/universal they dont have specific info for a Taco (or anything for that matter)
  15. Nov 27, 2010 at 8:25 PM
    Yoytoda
    Roland
    completely stock
    have you thought about the procomp ext length shocks, they are cheap and ive heard they work pretty good
  16. Nov 27, 2010 at 8:37 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    I hadnt, but I just looked at procomp's site and couldnt find anything. They list some shocks for 1" lift and some for 4" but nothnig in between. Did you have one in mind that could possibly work? Maybe a link?
  17. Nov 27, 2010 at 8:47 PM
    Yoytoda
    Roland
    completely stock
  18. Nov 27, 2010 at 8:53 PM
    Ridingontrd
    Richard
    Laughlin,N.V
    Pull one of your stock shocks and measure it compressed and extended.
  19. Nov 27, 2010 at 10:13 PM
    TurfTaco
    TurfTaco Is there a long john silvers on the island?
    URE
    07 Deer Collector
    285/75-16 BFG KM1's, AVS vent visors, AVS hood shield, pioneer avic F900BT, pac steering wheel control adapter, Boyo rearview camera, pac ipod interface, tinted windows, Toytec 1.5 AAL, Bistein 5100s (front set to .85) Eibach coils, Black headlights, grillcraft black billet insert, N-fab light bar, 4 Hella FF700 lights & color matched grille, Sockmonkey bedside decals. 16x8 MT sidebiters, Weathertechs, Fabtech spare carrier.
    I know you guys are talking about a 1st gen, but damn are you saying I have to replace my 5100s with the 5125s if I replace my aal with the ome leaf pack?
  20. Nov 27, 2010 at 10:14 PM
    Yoytoda
    Roland
    completely stock
    you dont "have" to but for the best flex/articulation/travel, yes
