Bilstein 5100s set at 2.5 with stock ucas?
Discussion in 'Suspension' started by BenH, Jan 26, 2012.
  1. Jan 26, 2012 at 4:29 PM
    BenH
    BenH [OP] Member
    Ben
    Cape Cod
    11 Tacoma Double cab extended bed
    My friend was saying that if I adjust the bilsteins to 2.5 he thinks I won't like how it rides because it will be alot stiffer on the stock ucas. Wondering if anyone has any experience with the bilsteins set at 2.5 with the stock ucas thnx for any help, Ben
  2. Jan 26, 2012 at 4:44 PM
    Frostbyte
    Frostbyte Well-Known Member
    Northern Utah
    18 Super White TRD OR Manual
    SOLD - 03 Black SR5 4x4 TRD OR RIP - 07 Radiant Red SR5 4x4 TRD Sport Fabtech 6" lift, 33x12.50.18 Toyo M/T on All black XD Hoss wheels
    You should be fine. Any lift over 3" would need UCA to keep your alignment in spec. Stiffness of that lift has nothing to do with the UCA anyways. You get the stiff ride because on that adjustable shock, your compressing how much downtravel the shock/spring has, causing it to be a more stiff ride. I have heard many people feel the ride at 2.5" is better than the stock ride anyways, and some dont, either way, billy shocks are good shocks, and you shouldnt be dissapointed.
  3. Jan 26, 2012 at 4:52 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    I have been running stock uca and 5100s at 2.5 for over a year now. IMO get the eibachs with 5100s or go for OME. The 5100s are nice but mine have stiffened up and are starting to ride worse it seems every mile I go. Just my .02
  4. Jan 26, 2012 at 4:55 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    I should also mention my alignment was within factory specs, it may not have been perfect but it was within spec.
  5. Jan 26, 2012 at 5:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    "In spec" can mean the following:
    Camber @ 1.2* and Caster @ .5*
    While those might be "In spec", the alignment needs to be more precise when larger tires are used. Camber should be below .4*, and caster needs to be greater than 2.2* or so.
  6. Jan 26, 2012 at 6:02 PM
    BenH
    BenH [OP] Member
    Ben
    Cape Cod
    Thnx for all the help I'm just going to set them at 2.5 and if I don't like the ride I'll get new ucas. I'm planing on putting the pro comp mud terrain 32 tires on it when I get some money
  7. Jan 26, 2012 at 6:52 PM
    Frostbyte
    Northern Utah
    Again, uca's won't affect the stiffness of the ride.... I think your mistaken about this. If you want a softer ride, you will need 885x springs, or eibach springs to go with your 5100's
  8. Jan 27, 2012 at 8:47 AM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    Yea I agree with Chris and also the weight of the 285 is much greater than the stock tire making every little degree more noticeable
  9. Jan 27, 2012 at 10:26 PM
    TACWUT
    TACWUT Well-Known Member
    San Diego
    12 prerunner DC
    Flowmaster turndown, 5100 up front/5150 rear, maxtrac spindles, 2" tuff country add a leaf+TSB.
    Why dont you check out the maxtrac spindles in the groupbuy section. Its a bit more but you wont worry aboit buying uca yada yada yada....lol i have the 5100 lifted at 2.5 and im going to get those spindles then lower it to zero or. 85.....
  10. Jan 28, 2012 at 7:34 PM
    TACWUT
    San Diego
    12 prerunner DC
    Oh i didnt realize he was a 4x4.
  11. Jan 28, 2012 at 8:03 PM
    TACWUT
    San Diego
    12 prerunner DC
    Yeah, not to thread jack but ill b getting some if the price is right. I will then set my 5100 at zero or. 85 to give me better travel and im hitting up DSM on monday to get my 5150 shocks.
  12. Feb 4, 2012 at 11:32 AM
    vtachtom
    vtachtom Member
    Tommy
    corona ca
    05 double cab prerunner trd
    Billie 5100's X4 with Deaver AAL in the back, more to come
    Nice thread guys. I wanted to know if any of you can help me
    I have a 2005 DC LB prerunner, about 6 months ago I installed the Billy 5100's and Deaver AAL. I kept my stock 17 in rims and put a 33 inch procomp all terrain tire on. I am running stock upper and lower control arms and the billys are set at the 2.5 setting with stock spring. Obviously the stock rims have no back spacing so I put spacers on to get clearance i wanted.
    the problem I am having is that my tires are now wearing on the outside of the both front tires. I think this is because the camber is off too far in the positive direction. what would correct the geometry of my front wheels? Is it instaling Uppercontrol arms or lower control arms or both or am i way off base all together?
    thanks Tom
