Bilstein 5100's set to the middle setting with 3 inch lift springs
Discussion in '1st Gen. Tacomas (1995-2004)' started by ffr3064k, Aug 30, 2010.
  1. Aug 30, 2010 at 9:14 PM
    ffr3064k
    ffr3064k [OP] Active Member
    Castle Rock, CO
    03 Double Cab debadged
    3 Inch lift, 32 x 11.50 Mudders, DVD, Headrest Monitors, Navigation, Sirius Radio, Subwoofers, Complete Color Change
    I have the Bilstein 5100's in front with OME Dakar leafs in the back. I would like to level the truck out and get rid of the slight rake. Would adjusting the Bilsteins to the middle setting of 1.25 with 3 inch lift springs from Eibach do the trick?
  2. Aug 30, 2010 at 9:17 PM
    TacomaNJ
    TacomaNJ Well-Known Member
    Central Jersey
    2001 TRD SR5 Tacoma Ext.Cab
    Alot of the experts on the forum would not recommend that considering that the Bilstein's are a "leveling kit" so they are not necesarrily made for the heavier duty springs like the OME 881's or other springs that provide lift.
    Based on the physics, I probably do not think it would be a good idea to have a preload on the bilstein with a eibach or OME spring.
  3. Aug 30, 2010 at 11:29 PM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    X2. The Bilstein is designed to work with the 375-lb progressive OEM coil. I'm not sure about Eibachs, but as another example, the OME 880s, 881s, and 882s are 500-lb nonprogressive springs. A lot stouter. The spring provides the lift, not the preloaded shock.
    I am not sure of the max travel of the 5100 set on zero, but you should look into that, because it would be your limiting factor in this application.
    Perhaps someone with more experience will chime in on your options here.
  4. Aug 31, 2010 at 6:00 AM
    ffr3064k
    Castle Rock, CO
    You both are confirming really what I already knew but when you go on Toytec's website the following statement is a little misleading under the Eibach springs: "Can be used with Bilstein Height adjustable shocks and other lift options for additional lift" The Eibach is a 620 lb 3 inch lift spring so it would seem to not be the correct approach to set the Bilstein at anything other than 0.
  5. Aug 31, 2010 at 6:02 AM
    ffr3064k
    Castle Rock, CO
    The person I talked to said the Eibach spring with the Bilstein set to 0 would be a good option.
  6. Oct 15, 2010 at 7:39 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    So is that what you are running now? Eibach 3" coils w/5100s set at 0 up front and dakars w/5100s in the rear? Thats the setup I was looking at. If thats how you have it, how is it working for ya? Any issues?
  7. Oct 16, 2010 at 10:01 AM
    ffr3064k
    Castle Rock, CO
    It works great and I love the look of the truck. I have taken it off road on some pretty rough stuff and it handled it like a charm. Good flex for off road and a pretty good ride on the highway. I had to extend the hanger for the muffler and I do need to extend the brake line if I intend to do a lot of wheeling in the future. The only issue I have had was during 4 wheeling, I got a little tire rub on the front of the rear wheel flares (real minor). I hear with the OME leafs it repositions the axle an inch or so forward. I think there is a inexpensive kit available to take care of that issue. You might want to consider installing that relocation kit while you are changing the leafs out. I got all of my stuff at toytech since they are local for me. Good luck..
  8. Oct 16, 2010 at 11:27 AM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    Great, thanks for the info
