Bilstein 5100's Setting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fitogarza17, Feb 19, 2015.
What Setting?
Poll closed Jul 19, 2015.
  1. 2.5 front, 1.5 rear
    28.2%
  2. 1.75 front, 1.5 rear
    35.9%
  3. 1.75 front, 0 rear
    35.9%
  1. Feb 19, 2015 at 9:02 PM
    MTyota
    MTyota Well-Known Member
    Bozeman, MT
    05 Tacoma 2.7 5spd SR5 4x4
    ABS switch, tailgate lock, factory fogs, tonnopro loroll, icharger aux cable, 10mm hex oil plug swaps
    Blocks and jacking the billys should be fine for looks but i wouldn't wheel on it at all. I would recommend a front dif drop kit and rear drive shaft bearing drop with that much lift to avoid driveline vibration as well. Also seems like a lot of people say to put a 1/4" spacer on the driver side coil to level it out
  2. Feb 19, 2015 at 9:04 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Technically no, but for safety's sake and because you are asking, then you probably should. Go to any autozone/pepboys/(places like that) and rent one.
  3. Feb 19, 2015 at 9:39 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    Don't do the front dif drop kit.
  4. Feb 20, 2015 at 5:52 AM
    Blze001
    Blze001 Breaks things.
    Virginia
    2013 TRD Sport DCSB
    IIRC the front diff drop is really only needed for 2"+, right?
  5. Feb 20, 2015 at 8:17 AM
    MTyota
    Bozeman, MT
    Yeah and he's talking about 2.5" by jacking stock coils on the billys, seen alot of friends with tacos rip through alot of CV boots. Not worth going over 2" in my opinion.
  6. Feb 20, 2015 at 8:24 AM
    darkfader
    darkfader Will this fit without rubbing?
    Josh
    West Virginia
    2018 DCSB6MTFTMFW
    I set mine at 1.75 and had a tiny bit of noticeable reverse rake, but I have a full toolbox in the bed. Firestone air bags were my solution, and I can haul whatever I want now, within reason of course.
  7. Feb 20, 2015 at 12:28 PM
    1tacoplease
    1tacoplease I like my truck!
    Temecula
    2008 BSP 4x4 6 speed
    265/70/17 BFG RT's, FJ 17" rims with 1.25" spidertraxx Debadged, HID's, URD short shifter, Bilstein 5100's in the front, TSB and 1" block rear, URD TCAI with maf calibrator, JBL long tubes, DT Y pipe, Gibson exhaust, Walbro 255 fuel pump, Pioneer stereo, Bak flip G2 tonneau, TRD skid plate, MB Quarts all around with dynomat, Viper Alarm with motion sensor
    Thanks. I have a 4x4 so front end should be a tad bit heavier and I use my truck as a daily driver and hardly wheel. Only use 4x4 to drive in snow and mud. Have not had any issues but like I said, I don't off-road and when I do, it's pretty light wheeling. It all depends on what you're going to use your truck for. Billy's and blocks are mainly just for looks.
