Bilstein 5100's - Should I?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Plinkerton, Mar 24, 2010.
  1. Mar 24, 2010 at 9:56 AM
    Plinkerton
    Plinkerton [OP] Well-Known Member
    NorCal
    2013 DCLB 4x4 SR5
    I've searched through threads, trying to find an answer, but I don't know anything about suspension, etc.
    I have a 2005 PreRunner, with 77,000 miles. It's a TRD Off-Road.
    Is there any reason to get 5100's? I have heard that it may be time to replace my shocks, and I figure since the 5100's aren't that expensive, it may be better to get them instead of the stock ones.
    Will these add any lift to my truck? Will I have to change anything else besides the shocks?
    Best case scenario, I wouldn't mind if they added some lift. I don't want to have to change/add anything else though. I would just want them to be a fairly easy replacement. I don't have the leaf TSB, but I haven't noticed a particularly "harsh ride" with a loaded bed either. Plus, I'm not in warranty.
    So, if I can buy these shocks, put them on, and maybe the 1.75 adjustment will work without me having to change or replace anything else, that's what I'm after.
    I'm not big into modding trucks, but I figured if my current shocks are getting close to the end of their lifespan, maybe I should go for something a bit better. I hope I'm understanding everything correctly.
    Thoughts?
    Thanks everyone.
  2. Mar 24, 2010 at 9:59 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    They have 4 positions of lift preset - 0, .85, 1.75 & 2.5". They are valved for lift and you can use your coils. Do it. If you do the 1.75 then I'd suggest the Toytec 1.5" AAL for the rear. It'll make it how it shoulda been from the factory for ride and load handling but not crazy harsh on the road. Mine rides much better with it. That should give you slight rake towards front but just off level where it'll be right if hauling stuff. If you go 2.5 then you'll need UCAs to get the caster back.
  3. Mar 24, 2010 at 10:00 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    :thumbsup:
    That's all you need. @ 1.75 it should level the truck out IIRC.
  4. Mar 24, 2010 at 10:25 AM
    DBZ 2010
    DBZ 2010 Well-Known Member
    Kahului, Maui
    2010 Wht Dbl Cab TRD Off Road PreRunner
    Gaylord TL Series Tonneau, 3 TSB's (Trans Re-flash, Rear Leaf Springs, Intermediate Steering Shaft), 5100 Bilsteins x 4 set at 1.75, Silver TRD FJ 16 inch Wheels, Wet Okoles
    Does your truck have a rake now? Or is it sittin level? If you have a rake to it (front end low, from factory) the .85 or the 1.75 will help you to level it out, but if your sittin level then the 1.75 setting might make your rig sit cali style (rear end low). So its up to you to decide how you want to do it. Also, if your thinking of going with the 5100 the 0 to 1.75 settings don't require other parts unlike the 2.5 which might need UCA's with the install.
    If I didn't get the rear TSB done I would've set mine at the .85 setting.
  5. Mar 24, 2010 at 11:33 AM
    Plinkerton
    NorCal
    2013 DCLB 4x4 SR5
    I'm kind of trying to avoid a lot of labor costs. I don't know how to work on trucks. Motorcycles are the only things I'm somewhat familiar with.
    I don't have the tools or a garage accessible to me at the moment, so I will be having the shocks, etc. installed.
    I figure the 5100's won't be much, as my dad had shocks on his truck done, and I was very surprised how cheap it was.
    As far as the AAL (I had to look up what it even was), the cost doesn't seem high, but it's definitely beyond my knowledge as far as installing.
    I don't really NEED 5100's at the moment, it was just a thought. So I'm trying to limit paying too much for all of this. I have some money available, but I'm not a "truck guy", so there are other things I'd rather spend money on.
    Do I need the AAL?
    As it sits now, as far as I know, it's essentially stock. So I imagine it's sitting how it sits from the factory.
    I'd be fine with the .85 setting, until I decide if I want to put an AAL in the back.
    Is that a reasonable way of thinking this out?
    Just 5100's, set to .85, and don't do anything else. If in the future I want it up to 1.75, I can add the AAL.
  6. Mar 24, 2010 at 12:08 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    I just switched out my stock shocks for these and I gotta tell you that the shocks on my '05 were toast. I knew it was bouncing too much over big bumps on the freeway. Now it hardly even moves when I hit those bumps. There's one where my wife would have to hold her coffee in the air to keep it from spilling. Now, you could be taking a sip and not even notice the bump. That's the difference between the 5100 and a stock '05 shock. FYI, you'll get charged anywhere from 2 - 3 hours of labor for the install on the fronts (you can call around for local labor rates). I called around before doing it myself. I added an AAL and set mine to 1.75. Love the height and looks (and it now feels like driving a cadillac compared to the before setup), but I have to put them back to .85 tomorrow since my front diff bearings are complaining (obviously, you won't have that problem with a prerunner).
  7. Mar 24, 2010 at 6:29 PM
    Plinkerton
    NorCal
    2013 DCLB 4x4 SR5
    So you think it makes sense then, to get 5100's, and that's it. Install them, and set to .85, and that's all I would need?
    If I decide to go 1.75, THEN I can get the AAL.
    That makes sense right?
    Then my other question, is are the shocks the same for the front and the back?
    Actually, I'll just call downsouth motorsports and ask them.
    Thanks again everyone.
  8. Mar 25, 2010 at 5:23 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Debadged, GC Mesh Grill, Yellow Fogs, Color Matched Headlights w/ Retros, Diff Breather Mod; mickey thompson classic IIs, 5100s, toytec springs, Dakar Leaf pack, ss brake lines, Lots more...just check the build page.
    ^^ yes.
    And the rears arent adjustable, if thats what you mean??
  9. Mar 25, 2010 at 3:06 PM
    Plinkerton
    NorCal
    2013 DCLB 4x4 SR5
    Ah, that's not what I meant.
    But I think I get it now.
    Thanks everyone.
  10. Mar 25, 2010 at 3:13 PM
    thegreatsam
    thegreatsam Well-Known Member
    Sam
    Vancouver, WA
    06 Double Cab TRD Off-Road
    I recently purchased an 06. I thought the hard ride was just due to it having the Off-road package. Even though the previous owner never did anything more than gravel hunting trails, do the front shocks eventually go bad anyways?
  11. Mar 25, 2010 at 3:19 PM
    rmerchant3
    rmerchant3 Insert nonsense here
    Just from that little bit of a lift with the angle change on the axles it's causing a problem? Can you actually hear them whining?
  12. Mar 26, 2010 at 2:49 PM
    Plinkerton
    NorCal
    2013 DCLB 4x4 SR5
    So it seems that the Bilstein 5100's front and rears will cost $299.00, and the Toytec 1.5" AAL costs $80.
    So that's not bad for the parts.
    Is that EVERYTHING I'd need to do this?
    Like if I walked into a shop, gave them all that, and said install them, and set to 1.75", that should be it?
    I don't need any other hoses, cables, etc etc. that I can't think of?
    Cause I'm gonna do it... :)
  13. Mar 26, 2010 at 5:44 PM
    05Moose
    Jim
    Yes, all shocks wear out. I read about someone that said they've tested them within 1 or 2 years after buying a vehicle and their performance declined at least 50 percent. I would believe it.
    Let's see, going with the 1.75 setting which raised the vehicle 2 inches (see my measurements in my post here: http://www.tacomaworld.com/forum/2nd-gen-tacomas/83271-5100s-wheelers-1-5-aal-installed.html), there was absolutely no way you couldn't hear it. Imagine a cyclical grinding sound that can be heard over the radio. It was loud enough that I fugured someone along the road could hear (but I doubt they really could since it just seems to be amplified inside the vehicle). Going down to .85 makes it much quieter.
    Yep! Buy the set of 4 shocks, purchase the AAL, install them, and get an alignment. That's it. No other parts needed.
  14. Mar 27, 2010 at 12:23 AM
    Plinkerton
    NorCal
    2013 DCLB 4x4 SR5
    What about new centering pins or "U" bolts?
  15. Mar 27, 2010 at 1:50 AM
    trd09
    trd09 Well-Known Member
    Chuck
    MA
    09 TRD Sport AC 4x4
    4-leaf TSB, 5100s @ 1.75, Flowmaster 40, Undercover Tonneau, K&N drop-in, Nittos, NGK Iridiums, OME N182s
    fwiw i have the tsb + 5100s @ 2.5
    1. i'm sitting level.
    2. i got an alignment after install and although caster may not be perfect, it rarely ever is and i checked the printout with the shop, all measurements are within spec.
    3. no gear whine. everything runs perfectly smooth.
    i actually had more shudders and vibes when stock than after 5100s and spacing the carrier bearing (cost me $2).
  16. Mar 27, 2010 at 8:06 AM
    05Moose
    Jim
    My AAL from wheeler's came with new center pins. My stock pins would have been too short. There's no excess on the pins and the extra leaf with it's higher curve wouldn't have allowed me to snug them together completely without the new pin and nut. Plus, you cut the excess off after the install because they still have to fit under the stock bumps (or my Timbrens which I kept on). Definitely get a clamp because that'll make life sooo much easier in dealing with the leafs.
  17. Mar 27, 2010 at 8:18 AM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    I have mine set at 2.5 with the 2"aal from toytec. It came with 2 new centering pins I did order new u bolts for peace of mind. Others just reuse their stocks.
    Edit. never reuse your stock centering pins.
  18. Mar 27, 2010 at 8:29 AM
    Taco4x4NC
    Taco4x4NC Well-Known Member
    David
    Western North Carolina
    2010 4x4 DC/LB "Pytrite Mica/Katzkin leather
    3m clear bra or Venture, stant locking gas cap, Shield, front windows tinted, weathertechs, ARE "Z" topper. Sockmonkey decal, Billy 5100's x 4 corners, Eibach coils, Toytec 1.5 AAL. Michelin 265/75/16 MS2's, Grillcraft MX series/TOYOTA badging. FJ/SE TRD Anthracite gray wheels. Katzkin leather/heated seats.
    Much better ride than stock. I set the Eibachs at zero and am very happy with the slight lift and more stable, less spongey ride. No regrets. My pic is a little nose up do to the topper weighing in a 190lbs. This may go away with the rear leaft TSB. Best of luck.
  19. Mar 27, 2010 at 11:26 AM
    Plinkerton
    NorCal
    2013 DCLB 4x4 SR5
    Thanks everyone. Time to call around for some install prices.
    Or find someone who knows what they're doing.
  20. Mar 27, 2010 at 12:01 PM
    69z28
    69z28 Hell bent for leather
    Kenmore, Washington State
    2006 D-Cab Sport 4X4
    I just had the 5100's installed on my 06 double cab 4x4( front only ) sits
    nice and level at 1.75" setting. I have NO REAR MODS. You might be disappointed with the .85 setting, although maybe prerunners are different than 4x4's. Check out my post in the recent threads ( from 69z28) to see pics of my truck.
