Bilstein 5100's vs 4600's
Discussion in '1st Gen. Tacomas (1995-2004)' started by warren_454, Jul 13, 2012.
  1. Jul 13, 2012 at 5:13 PM
    warren_454
    warren_454 [OP] Member
    Adam
    Ky
    02 TRD Tacoma
    TRD cat back, K&N cold air intake.
    Im needing new shocks and I was wondering if I can put the Bilstein 5100 on a stock 2002 TRD tacoma, no lift. The part search on Bilstien and other websites pull up the 4600's. I see on here the 5100's are highly recommended for lifted trucks, I was just wondering if they will fit on a stock ride hight.
  2. Jul 13, 2012 at 5:18 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    yes the 5100's will work they have setting for 0 .85 1.75 and 2.5 for 2nd gen trucks and i think its just 3 settings for 1st gen. but regardless you'll be fine with the 5100's :)
  3. Jul 13, 2012 at 6:55 PM
    Parsec42
    Parsec42 Well-Known Member
    Tyler
    Oregon
    98 Tacoma SR5 V6 4x4
    UWS low pro black, Wet Okoles, Eibachs, Bilstein 5100, Total Chaos UCA, Wheelers 5-leaf pack, deck plate mod & Afe Pro Dry, plastidipped badges
    If you want to stay at stock height you need the set from Downsouth with 5100 adjustable fronts and 5125 rears because they are shorter in the rear travel than the normal set of 4 5100s that are designed for a couple inches of lift.
    Edit: Link
  4. Jun 5, 2014 at 1:42 PM
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
