Bilstein 5100's.... Want to go 1-2" higher... HELP!
Discussion in 'Suspension' started by jeremy25056, Aug 22, 2011.
  1. Aug 22, 2011 at 10:25 PM
    jeremy25056
    jeremy25056 [OP] Well-Known Member
    Los Angeles
    11 TRD OFF-RD AccessCab 6Spd
    Title says it all, I have 5100 bilstein's set at top hight. How do i got about lifting another inch or two. What complications will i run into? will it be as easy as adding a spacer on top of the strut? or body lift?
    Thanks for all your help.
    Jeremy
  2. Aug 22, 2011 at 10:32 PM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    So ur sitting at 2.5. U could add a .25 spacer to each side. Anything else over that is not recommended.
  3. Aug 22, 2011 at 10:40 PM
    jeremy25056
    Los Angeles
    Gotcha, not recommended meaning...??
  4. Aug 22, 2011 at 10:41 PM
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    Its not recommended if you want to keep your truck running in good working condition
  5. Aug 22, 2011 at 10:42 PM
    yotamikez
    yotamikez Street glide or die
    Valrico
    04 civic & 08 Street glide
    Are you 2wd or 4wd?
  6. Aug 22, 2011 at 10:43 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    Anything higher than 3" puts too much stress on your CV boots and stock UCA's...Overall not a good idea.
    To go higher than 3" you need to start looking at dropped bracket lifts.
  7. Aug 22, 2011 at 10:45 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    If you are 2wd you can go spindles
    if 4wd , you can go about 3 1/4" max or go to a drop bracket lift to go higher
  8. Aug 22, 2011 at 10:46 PM
    yotamikez
    Valrico
    This is what I was getting at :D tanks OZ
  9. Aug 22, 2011 at 10:49 PM
    jeremy25056
    Los Angeles
    I am 4x4. Drop brackets.... Im sorry for being a newb... anyone have a link to some reading up i can do on it?
    Say i just do the spacers, will i have to worry about the lift/alignment?
    Jeremy
  10. Aug 22, 2011 at 10:52 PM
    yotamikez
    Valrico
  11. Aug 22, 2011 at 10:52 PM
    OZ-T
    Peter North
    British Columbia
    You don't wanna stack lifts
  12. Aug 22, 2011 at 10:56 PM
    jeremy25056
    Los Angeles
    I didn't mean lift, i meant just spacing the wheels/tire out.
  13. Aug 22, 2011 at 10:56 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    I'm not a DB lift expert. look up pro-comp and fabtec 6" lifts. I think rough country makes a 4" too.
    With the spacers, on top of the 2.5, you'll probably have alignment issues, on top of stressed CV boots.
    EDIT: didnt see you reply to oz about the spacers.
  14. Aug 22, 2011 at 10:57 PM
    OZ-T
    Peter North
    British Columbia
    Oh , sorry
    Yes you can add wheel spacers , you shouldn't need to re-align it for that .
  15. Aug 22, 2011 at 11:07 PM
    jeremy25056
    Los Angeles
    Thank you for the input.
    Well i guess i will start there and see how it is. Any recommendations for spacers?
    J
  16. Aug 22, 2011 at 11:10 PM
    OZ-T
    Peter North
    British Columbia
    Lots of guys on here running these
  17. Aug 22, 2011 at 11:12 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Spidertrax spacers are good
