Bilstein 5100's with aal or block?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BullySince1972, Mar 14, 2022.
  1. Mar 14, 2022 at 10:55 AM
    BullySince1972
    BullySince1972 [OP] Active Member
    2021 Cement Tacoma SR5 Trail
    Looking for some input....
    I purchased a set of Bilstein 5100's (front and rear) today and now I'm trying to decide on a block or aal and what size?
    Currently I have a 2021 mostly stock Tacoma (no added weight) that I would like to lift about 2". Primarily a daily driver but I do hunt and fish some, not an off-roading guy other than that. On flat ground with consistent tire pressures in each tire I'm sitting at 35" DS - 35 1/4" PS in the front and 36 1/8' DS - 36 1/8" PS in the rear. I would like to maintain about 1/2 - 1" rake if possible.
    Is block or aal the route and what size?? Don't want a rough ride when I'm finished if that makes sense.... If block should it be tapered or not? Links to recommendations would be helpful. Thank you for your thoughts!
  2. Mar 14, 2022 at 10:56 AM
    GOROAM
    GOROAM Where can I get Raptor lights?
    19 TRDOR
    Crawling Malls
    Neither…go RXT leaf pack. Why are you skimping on suspension on your $45k rig?
    eurowner likes this.
  3. Mar 14, 2022 at 11:05 AM
    coma toy
    coma toy Off Road Taco
    If you don't carry weight or tow a lot, the block is just fine. If Toyota sells it in their TRD Lift kit, it cant be bad.
    I wouldn't do more than 1" block...
    P.S. A 2/1" lift is level, no rake. You could do 1" in front, and NO block in rear for a factory looking rake.
  4. Mar 14, 2022 at 11:05 AM
    BullySince1972
    Not a big modding guy but I thought I was upgrading it?? I have a SR5
  5. Mar 14, 2022 at 11:08 AM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    :playball:
    gsubioguy likes this.
  6. Mar 14, 2022 at 11:28 AM
    CMillTacoma
    CMillTacoma Well-Known Member
    Craig
    Colorado
    2025 TRD OR Hybrid
    I have a 22' TRD OR SB and I maintained 1in rake by doing wheelers single leaf AAL and Toytec's 1/2 block, truck sits at exactly 1 inch higher in the back. Front is 6112 on 3/4 notch and a 3/8in top spacer for slightly more than 2 inch lift, ride is very good IMO.
  7. Mar 14, 2022 at 11:34 AM
    GOROAM
    19 TRDOR
    Crawling Malls
    AAl or block are the new which Raptor lights to go with.....:bananadead:
  8. Mar 14, 2022 at 12:58 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Put your Bilsteins on the 4th perch, add a 1/4 shim on the drivers front for the lean, add a one inch rear block and you will have a very slight rake, still allowing you to have a nice riding truck and still put some weight in the bed when needing to haul something. A one inch block is perfect anything more do an aal. Look at mayby using a front diff drop and a rear carrier drop, do the ecgs clam shell bushing. Do lift first and check for vibrations if none present themselves then you good.
    Siltaco56 and BullySince1972[OP] like this.
  9. Mar 14, 2022 at 1:03 PM
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    Look into Road Master Active Suspension. It is totally DIY and you can adjust the rear pre-load if you decide to add a topper or tow a camper for example.
    BullySince1972[OP] likes this.
  10. Mar 14, 2022 at 1:14 PM
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    BTW I resemble that remark :eek:
    But I respect those who don’t.
  11. Mar 14, 2022 at 1:26 PM
    BullySince1972
    Thank you!
    This the type of shim you are referring to?
    https://www.headstrongoffroad.com/store/p31/HS_1/4"_Top_Plate_Spacer_-_TT05514-TPS.html#
  12. Mar 14, 2022 at 1:32 PM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    I wouldn't really call an AAL skimping. It does come down to OP's usage though. Anything more than an AAL for myself would be wasting money due to my current usage. A block however though is another story.
  13. Mar 14, 2022 at 1:33 PM
    CalcityRenegade
    2023 T4R ORP KDSS
    I myself would stay away from the block. AAL will give you left while retaining good ride quality as well as better support for carrying anything heavy in the box.
  14. Mar 14, 2022 at 1:38 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Go with a 3 leaf add a leaf.
  15. Mar 14, 2022 at 1:41 PM
    VaToy
    Parts Unknown
  16. Mar 14, 2022 at 1:43 PM
    na8rboy
    WI
    As for shim, one degree per each inch of lift is rule of thumb.
  17. Mar 14, 2022 at 1:56 PM
    Ashgh
    Ashgh Well-Known Member
    Ashkan
    2021 Tacoma TRD Off-road
    I agree with going with the icon rxt leaf kit if money is not a problem. This especially if you plan on having weight in the bed later on.
  18. Mar 14, 2022 at 2:04 PM
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    A 3 leaf AAL isn’t the most expensive or very best option out there, but still a lot better than a block (and AALs are pretty easy on the wallet too). At least an AAL will increase your payload capacity and help prevent your leaf springs from flattening out or backbowing. A block only increases the pressure on the leaves and contributes to flattening. So I think an AAL is a great choice for the money. I’d have no reservations about broverlanding my rig for years on an AAL, if that was my thing. If I was going to make my Tacoma into a rock crawler, I’d go with a new leaf pack and some fancy shocks, but IMO there are so many better choices for a true trail rig than a 3rd gen Tacoma… with smaller wheelbases, no safety/nanny shit, and no worry about banging up a $45K new truck.
