Bilstein 5100's with aal
Discussion in 'Suspension' started by jordando89, Jun 13, 2011.
  1. Jun 13, 2011 at 6:12 PM
    jordando89
    jordando89 [OP] Well-Known Member
    jordan
    idaho
    2008 white double cab long bed sport 4x4
    3in lift painted sport wheels
    if i buy Bilstein 5100's and add a leaf do i need ucas or will my stock ones work fine? i have a 08 double cab sport Lb v6 4x4.
  2. Jun 13, 2011 at 6:15 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    What setting do you plan to run the 5100s at?
  3. Jun 13, 2011 at 6:16 PM
    CopDoctor
    CopDoctor Well-Known Member
    Trinidad, CO
    2018 Quicksand TRD Off-Road
    well, sir. as has been discussed in great lengths in dozens of other threads, it depends on how much lift you are going to. anything 2.5-3in and higher you will most likely want new UCAs to keep your alignment in spec. if you forego the new UCAs, your truck will be subject to drastic wandering and will sooner or later make you shit your pants and purchase the new UCAs.
  4. Jun 13, 2011 at 7:09 PM
    tacomtn
    tacomtn Well-Known Member
    TRD OR,OME,Deaver AAL
    Ive been wondering the same thing with 2.5" and higher. I talked with a dude at DownSouth Sports re: lifts and Bilsteins 5100's, which he installs in many Tacos. He was saying that the alignment would be at the end of the factory spec's for caster (which can cause wandering) but should be okay. Like oswego said, "should". Somehow it seems some trucks are okay, others not.
    Why the variance when using the same parts?
  5. Jun 14, 2011 at 9:20 AM
    larry2375
    larry2375 Well-Known Member
    honolulu
    2010 mgm prerunner sport
    upper mx grillcraft, flowmaster super 44,bilstein 5100 @ 2.5,toytec 1/4" spacer driver side,nitto terra grappler 285/70/17,17x9 xd addicts, undercover tonneau cover, wet okoles, weathertech mats, toyota door sill protector, toyota bed mat, 30% tint, black toyota oem tube steps, 14" shorty antenna, trd skid plate, most important, viper 5902 with remote start and two dual shock sensors
    I have mine set to 2.5" plus the 1/4" spacer for driver side lean and caster is on the low side but haven't noticed any wandering.
