Bilstein 5100's with OME 885 Coils
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brad88nl, Nov 25, 2010.
  1. Nov 25, 2010 at 2:04 PM
    brad88nl
    brad88nl [OP] Member
    Brad
    Penticton, BC, Canada
    2010 Double Cab 4x4 TRD Sport
    3" Toytec Ultimate Lift, Light Racing UCA's
    Sorry for beating another 5100 question into this Forum guys... I've read most of the previous threads and haven't had much luck.
    I just ordered my 5100's all around and I've been reading a lot of mixed thoughts and reviews about after market coils in conjunction with the 5100's.. Just wondering if adding coils to the 5100's would improve the ride?
    I was given a great deal on some ome 885 coils, but the more I read, the less I think I'll be able to use them with the 5100's... I'm just trying to get an idea of how many people have had experience with the set up and if its recommended.
    Any thoughts would be appreciated!
  2. Nov 25, 2010 at 2:11 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I have that exact setup but with the top plate spacers as well for the full 3"s of lift up front. You just have to set your 5100's at 0" height cause the coils will do the lifting. If you dont have the top plate spacers, I've heard of other people setting their 5100's at .85"s to reach a full 3"s of lift. But if you dont, it will sit around 2.5"s just from the lift of the coils. I love how my truck rides!! A little stiffer then stock but that doesnt bother me.
  3. Nov 25, 2010 at 2:41 PM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    I had that set up on my old tacoma. It was fantastic. I also set a 0 and used a spacer.
  4. Nov 25, 2010 at 3:25 PM
    Gabex35
    Gabex35 Well-Known Member
    Gabe
    San Diego
    2020 Tundra Limited 4x4 Crewmax
    I installed the 5100's with 885's last weekend. I also used the 1/2" spacers and found that i got 3-3.25" of lift. I like the ride , not too stiff.
    I kind of wish i had used the 1/4" spacers instead of the 1/2" cuz my inner CV boot fins are a little to close for my liking. but other than that, i am really happy with the way the truck drives/feels
  5. Nov 25, 2010 at 3:41 PM
    brad88nl
    Brad
    Thanks guys, that makes me feel a lot better with my choice.
    I'll probably try without the spacer first just to see how it sits, before going out and buying a 1/4" or 1/2" space.
    I guess any time you go 2.5" or higher with a lift, uca's and a diff drop should be added to the bill as well?
    WW_FIREFIGHTER have you had any problems with your CV boots with this set up?
    Thanks again!
  6. Nov 25, 2010 at 3:43 PM
    badguybuster
    Michael
    Unless you have a winch or heavy bumper you should be close to 3". You will not be sorry. If I were you though I would add a small touch of JB weld to the retaining clip. Several people I know have had the ring pop loose with this set up.
  7. Nov 25, 2010 at 3:56 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    I know some people that have 3" lifts with stock UCA's and they say they have no issues but it is always recommended to go with aftermarket ones.
    No I have not had any issues with my CV boots (knock on wood) and I also have the front diff drop kit installed on my truck.
  8. Nov 25, 2010 at 4:06 PM
    Gabex35
    Gabe
    San Diego
    Which retaining clip are you applying the JB Weld to?
  9. Nov 25, 2010 at 4:13 PM
    badguybuster
    Michael
    To the ring on the 5100's. there are several guys on here who can vouch for the ring popping off while off roading. I had it happen while driving up a rough logging road on way to a horseshoeing appt. I added it after that and never had another problem. Did it to my Tundra 5100's too.
  10. Nov 25, 2010 at 4:31 PM
    LouTaco
    LouTaco Well-Known Member
    Lou
    Des Moines, Iowa
    2018 T4R SR5 Premium
    5100 and 885 coils ride nice stiffer than stock but i had stock coils and fronts set @ 2.5 and i felt like it was a little harsher [​IMG]
  11. Nov 30, 2010 at 2:08 AM
    HarryTaco
    HarryTaco Well-Known Member
    Pacific NW
    2016 TRD OR DCSB 4x4 V6 MGM
    Bed Mat, Bak Revolver Tonneau,
    Do I need sway bar relocate with this setup?
  12. Nov 30, 2010 at 7:35 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    I didnt get one. Now issues with mine.
  13. Dec 26, 2010 at 5:22 PM
    BassMaster06
    BassMaster06 Well-Known Member
    Dan
    South Carolina
    2006 Double Cab V6 4x4
    Mods: sand, dog hair, roof rust
    can i get 285s on stock 16" wheels in with this setup? or are wheel spacers necessary?
  14. Dec 26, 2010 at 6:07 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Spacers will be necessary to run 285's on your stock wheels.
    Spidertrax makes good ones.
    Tac11 likes this.
  15. Dec 26, 2010 at 6:27 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    Ring popping out?
    I can only see it happen if the collar is upside down.
    Seems like the collar would keep the lock ring in place if it started getting frisky.
    JB weld would make it pretty much on for ever don't it?
    Anyone else have it happen?
  16. Dec 26, 2010 at 6:33 PM
    TexasTacoma37
    X2. When installed properly, the spring perch hugs around the ring and basically crushes it into place. Can't see it actually having the room to expand and slip off.
  17. Dec 26, 2010 at 6:39 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    I had this setup... it was fine, but I did not like it
    It was too stiff and my 285/70/17 tires did not fit without rubbing, plus it seemed like I still didn't get a full 3" I had 885s with 5100 (set at "0") and LR UCA w/ .5" top plate spacer.
    I'm sure it was a full 3" but seemed smaller next to other 3" trucks. I really needed the spacer because w/o I only had about 2.25" but the Truck rode perfect without the spacer but with the spacer it was a bit too rough.
    So I ditched it and went with RCD 4.5" lift. With the 3" lift my tires rubbed going over any bump and real bad when offroad.
    I've rode in trucks with 5100s set at 2.5" w/ stock springs and this 885 setup will ride a lot smoother and a bit softer (even with spacer), but if I did it again and wanted a smaller lift I would have left out the spacer.
  18. Jan 16, 2011 at 6:44 PM
    michaelg589
    michaelg589 Well-Known Member
    I'm sorry to high jack but, do you guys think I should go with 885s or 884s for my Double Cab? I dont really want more than 2" of lift. Thanks!
