bilstein 5100's
Discussion in '5 Lug' started by showzer, Apr 25, 2011.
  1. Apr 25, 2011 at 3:44 PM
    showzer
    showzer [OP] Well-Known Member
    Shea
    San Diego
    '98 reg cab
    fabtech UCA, Fabtech coil spring, Pro Comp es3000 shocks, flow master exhaust, K&N Intake, throttle body spacer, rhino lined, hella 500 lights, prerunner bumper in the making
    this has probably been said before but I am curious why bilstein 5100's do not fit on the 5 lugs
  2. Apr 25, 2011 at 3:49 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    too long of a strut to fit in the 5 lug suspension
  3. Apr 25, 2011 at 3:51 PM
    showzer
    Shea
    San Diego
    '98 reg cab
    even if it has a lift on it?
  4. Apr 25, 2011 at 3:54 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    most likely. im not sure how long yalls struts are but if they are over 3 in longer they are to big. also you would need the springs off of a 6 lug to use with the 5100s im pretty sure. dont quote me on any of this...
  5. Apr 25, 2011 at 7:50 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    1st gen 5 lugs dont have struts they have coils
    ive heard of guys using 5100's from tahoes and siverado 1500s wit some fab work but not sure if they will bottom out with our suspensions. id do some research on that or ask them the results
