Bilstein 5100's
Discussion in '1st Gen. Tacomas (1995-2004)' started by josephduanehanson, Mar 16, 2012.
  1. Mar 16, 2012 at 8:00 PM
    josephduanehanson
    josephduanehanson [OP] MEMBER
    Joe
    Omaha, Nebraska
    03 Tacoma TRD V6 4X4
    ARB bull bar bumper, Trail Gear rock defense rear tube bumper
    I'm thinking of purchasing bilstein 5100 adjustables for the front, will i need anything else or will they work with my stock springs?
  2. Mar 16, 2012 at 8:08 PM
    chaz834
    chaz834 Tacoma 4 Life.
    Chase
    Kendrick, Idaho
    2012 Sport MGM
    3'' Tuff Counrty Lift, Moromoto Mini H1 Projectors 5000K 35W, BHLM, 30'' LED Light Bar, Black TOYOTA Emblem, Excelon Touch Screen Deck, Hertz Speakers,Excelon AMP, 2 10'' JL Audio Subs, Wet Okle seat covers, Weather Tech Floor Mats.
    They will work with stock springs I bought the 5100s with the Toytec Eibach coils I love the setup allot of guys on here are running it...
  3. Mar 16, 2012 at 8:09 PM
    lonzorizo
    lonzorizo Well-Known Member
    Lonnie
    Hoopa, Ca
    2003 TRD OR, 2016 TRD OR Tacoma
    Try searching....
    they will work with stock springs and adjust up to 2.5". The better option would be to order lift coils and set the shocks at 0" though.
  4. Mar 16, 2012 at 8:12 PM
    josephduanehanson
    Joe
    Omaha, Nebraska
    i was just going to use them for a leveler, so just the 1" or 1.25" to help out my arb in the front
  5. Mar 16, 2012 at 8:25 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    With the kind of weight the arb has putting it at the 2.5 setting will probably be level, the stock springs arent made for all that extra weight which is why it would be a better choice to get eibachs or either go OME and run 882's to compensate for the weight of the bumper and or winch if you have one or plan to add one
  6. Mar 16, 2012 at 9:48 PM
    josephduanehanson
    Joe
    Omaha, Nebraska
    thanks for the info. I was also going to get the differential drop kit, does this help at all?
  7. Mar 16, 2012 at 9:51 PM
    magikbean562
    magikbean562 once flirted with danger, danger got clingy
    greg
    socal
    pinto
    33" mudders
    nope. search around. i heard the diff drop will actually do damage. and for the front, your stock setup is almost 10 years old. buy some eibachs for like $150 and do it right the first time.
  8. Mar 16, 2012 at 9:58 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Wtf?? No..no no no
    Diff drops do work on 1st gens. They don't help a ton but do help. Its 2nd gens that it does nothing.
    OP if you run the Eibachs, for sure get a diff drop and also do a search on the Boot Slide mod. You'll want to do that as well.
    However, if you run Eibachs, you'll want an AAL too cause the Eibachs will lift the front 3'' easy with the ARB. I am running them and have an Elite bumper and still have over 3'' of lift.
    OME 882s would work great as well.
    Do some searching for pics and such. There is a HUGE thread on the Eibachs we started just last fall with lots and lots of info on them and pics.
  9. Mar 16, 2012 at 10:40 PM
    josephduanehanson
    Joe
    Omaha, Nebraska
    that mod seems pretty easy, and seems to work
    ill have to do that!
