Bilstein 5100s
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dean724, Oct 13, 2015.
  1. Feb 9, 2016 at 6:48 AM
    #201
    redbull9944
    redbull9944 Well-Known Member
    Southwestern PA
    2016 DCSBTRDOR Inferno 6MT, 2004 Double Cab 4WD Project
    Prinsu Rack, 275/70R17 Cooper ST MAXXs, TRD PRO 4Runner Wheels, 5100s
    lol
  2. Feb 9, 2016 at 8:32 AM
    #202
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco
    some and more and more and more and
    I have a question that might have already bean asked. If I wanted to rake the rear a little more than it is stock, say like 1" to 1.5". Can the 5100"s do it on there own or do I still have to do a AAL or a blocks?
  3. Feb 9, 2016 at 8:39 AM
    #203
    redbull9944
    Southwestern PA
    5100's do nothing for the rear as far as height is concerned. If you wanted 1.5 inches of rake I'd set the front to the .85 setting and do either an AAL or a block in the rear. You'd still have to get the 5100 rear shocks because they are extended length though
    I have about .5 or .75 inches of rake at my setting
  4. Feb 9, 2016 at 8:45 AM
    #204
    smugly
    Doug
    Thank you!
  5. Feb 9, 2016 at 8:48 AM
    #205
    redbull9944
    Southwestern PA
    Sure thing
  6. Feb 9, 2016 at 7:57 PM
    #206
    Mason04
    Mason04 Well-Known Member
    Texas
    18 TRD OR 4x4, 17 4runner TRD OR 4x4, 75 FJ40, 94 4x4
    Stock coils
  7. Feb 10, 2016 at 6:56 AM
    #207
    redbull9944
    Southwestern PA
    It would be tight. If you weren't going to do a lot of off roading you might be able to get away with it
  8. Sep 6, 2016 at 5:26 AM
    #208
    ievko82
    ievko82 Well-Known Member
    WV
    17 sport DCSB quicksand
    Is it pretty safe to say that 5100s set on 1.75 and trd sema wheels with 275/70/17 tires will fit without alot of problems? I realize on a sport the front air airdam will have to come off or be trimmed but I don't want a bunch of rub or have to chop up the truck.
  9. Sep 24, 2016 at 8:32 PM
    #209
    motoglen
    motoglen Well-Known Member
    brandon
    UTAH
    16' tacoma Limited
    billies set at 1.75 front and 1 inch block in the rear. 285/65r18 nittos
    2016 limited.
    285/65r18 k02
    5100s @ 1.75 stock coils
    1" low range block in the rear
    Only rubs so far on the air dam. Debating on trimming or removing it.
    2016TacomaTRD likes this.
  10. Sep 25, 2016 at 2:36 AM
    #210
    ievko82
    WV
    Looks good. Any side shots?
  11. Sep 25, 2016 at 10:12 AM
    #211
    motoglen
    brandon
    UTAH
    16' tacoma Limited
    Here is some side shots.
