Bilstein 5112’s rear shock assembly
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NmapFE, May 9, 2022.
  1. May 9, 2022 at 7:26 AM
    NmapFE
    NmapFE [OP] Well-Known Member
    2014 DCLB 4x4 Limited. 6112’s/5125, KYB Top Hats, SPC UCA’s, Icon RXT leaf pack,
    CORRECTION!!! 5125’s NOT 5112’s. I’m sorry about my mixup. There basically no instructions to assemble . Do I just copy the stock assembly?
    here is what comes with the shock
    2C17E553-F86B-4D81-B8DE-914D36210DD2.jpg CCC41BBA-9E5B-4F45-B636-7591565B6144.jpg
  2. May 9, 2022 at 7:34 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    yeah just copy the stock assembly. Do note you need to shave down the lower bushing sleeve and cut the rubber bushing to match so that it will fit in the shock mount on the axle.
  3. May 9, 2022 at 7:34 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Yes.
    (from bottom to top) Washer > bushing > truck mount > bushing > washer > nut
    NmapFE[OP] likes this.
  4. May 9, 2022 at 7:37 AM
    NmapFE
    Ok thank you
    drizzoh[QUOTED] likes this.
  5. May 9, 2022 at 7:42 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    NmapFE[QUOTED][OP] likes this.
  6. May 9, 2022 at 7:59 AM
    NmapFE
    How does one know which side faces the front of the truck when installing the leaf pack?5EBD58C4-6B43-4AEA-9CFE-D259C0C0F62B.jpg
  7. May 9, 2022 at 8:01 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    Those look like RXT's. For those, the side with the 2 shackles pointing up should be forward.
  8. May 9, 2022 at 8:24 AM
    NmapFE
    Thanks .. those are RXTs
  9. May 9, 2022 at 8:38 AM
    NmapFE
  10. May 9, 2022 at 12:33 PM
    NmapFE
    Looking for advice on how to get the top of the shock
    Ok question. Using the supplied washers and bushings there is no room left for a bolt on top…(see pic) what am I doing wrong? There are two bushing the exact same size.
  11. May 9, 2022 at 12:52 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    That's pretty common for the threads to be short. Just need to grab a few and you can start cranking down. Make sure the little raised circular part in the center of the bushings is properly seated inside the little wider hole in the body mount if it allows for it (I don't recall if my third gen needed this but other vehicles I've had needed this).
    This thread shows how they should be positioned: Rear Bilstein 5125 Shocks - extended length - SOLD | Tacoma World
  12. May 9, 2022 at 12:58 PM
    nd4spdbh
    SoCal
    Spin the bushings around so the pointed end fits the cups of the mating surfaces.
    drizzoh and NmapFE[OP] like this.
  13. May 9, 2022 at 1:09 PM
    NmapFE
    Thanks all for the feedback! Taking a break at a this point and going to try these options in the morning. I’ll let you know how it goes and thank you so much. Semper Fi!
    nd4spdbh and drizzoh like this.
  14. May 9, 2022 at 2:48 PM
    NmapFE
    So to confirm: you’re stating that one needs to cut the bushings down that fit on the top shaft? For example:cutting where the yellow line is-ish?
  15. May 9, 2022 at 3:54 PM
    nd4spdbh
    SoCal
    No no. What you quoted was talking about the axle side not frame side.
    To get the top side to fit, flip the bushing on the stem so that it follows the contour of the cup in the frame.
  16. May 9, 2022 at 5:26 PM
    NmapFE
    Got ya. Thank u
  17. May 9, 2022 at 5:35 PM
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    EE2A4CC6-B8FD-495D-82E9-D287C8DB7F28.jpg Here's a picture of the assembly instructions that came with my 5160s.
  18. May 9, 2022 at 5:35 PM
    jackn7
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    I saw you start this thread earlier but couldn't get a picture till I got home. Hope it helps.
    Edit: I guess I'm a bit late. Sorry about that.
  19. May 9, 2022 at 5:42 PM
    BattleKat
    BattleKat Well-Known Member
    San Diego
    2021 TRD Offroad 4x4 - Army Green
    6112/5160s Icon RXT Leaf Pack (Option 2) Cali Raised 0-Degree Rock Sliders Cali Raised Bed Stiffeners Talon's Garage Cat Shield TRD Skid Plate ARE MX Interchangeable Yoda Dashboard Buddies
    Would love to know the exact set of upgrades you are doing to front and rear and see before and after pics with measurements. In the next 4 weeks I'm upgrading to 6112/5160 and the Icon RXTs. Still debating on different settings on the 6112s and what option to use on the RXTs.
  20. May 9, 2022 at 5:52 PM
    jackn7
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    The new 6112s have I think eleven settings. I went with 7 on the passenger side and 9 on the drivers to compensate for the lean. I've got an icon three leaf ad a leaf for the rear. Forgot to measure. Also, no over load.
