Bilstein 5125 techical question.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sdcrofts, Jan 21, 2018.
  1. Jan 21, 2018 at 3:41 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Persuasion...
  2. Jan 21, 2018 at 4:36 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Yes, thats the word I was looking for :D
    DrFunker[QUOTED] likes this.
  3. Jun 21, 2018 at 2:41 PM
    smartbomb
    smartbomb rcvr/xmtr
    usually northwest of you
    2006 4-door prerunner long bed
    3" suspension lift, hard canopy, light bar in hood, ditch lights, aircraft cargo bars, powdercoated steel spares, desert tires, bed cargo bars (for rifle cases), misc interior doo-dads
    necropost, got it.
    but I simply cut the sleeves down to 28mm to fit rather than beat the mounting brackets with a rock.
    The sleeves can be cut with a hacksaw and just finished up sandpaper
    I kinda cheated and used a bandsaw and a benchtop belt grinder.
    if the bushings are the same as the ones they sent me, you'll have to trim some of it. I simply used one of the sleeves as a guide to cut after I pressed it in, then I re-pressed it so it was centered in the bushing again
    FYI, an 11mm socket works great to for pressing the sleeves into the bushings
    install the top end of the shock, just enough so it stays in the mount
    1-inch ratchet strap hooked into the frame
    run the ratchet strap webbing under the bottom of the shock
    ratchet until shock is above mount, slide shock over mount location
    release ratchet, guide bottom of shock into mount
    position bottom shock mount into position with large flathead screwdriver
    bolt it all up
    have a nice day
    I hope this is helpful to someone
  4. Oct 28, 2023 at 9:24 PM
    Inavandownbytheriver
    Inavandownbytheriver Well-Known Member
    Earl
    2002 Toyota Tacoma trd
    Sorry to revive an old thread but it's close to answering my question. I have the Icon rxt leaf pack which has raised my back end 2 inches. Today on a rough road I bottomed out my stock rear shocks causing luckily only a loud noise. I am planning to replace the rears with shocks that make up for the lift but am unsure if bilstein 5100s will work for that much lift? I read they are rated for up to 1 inch of lift. If not, are 5125s what I should get?
  5. Dec 23, 2023 at 12:41 PM
    Aroy608
    Aroy608 Member
    Adam
    SSM Ontario Canada
    2017 TRD Sport Silver
    Forestone Destination AT2 P265/65r17 Rear Air Lift air bags
    I've had them on for over a year now and the lower bushings are shot. I can't for the life of me find the replacement part. Anyone needed to replace them find them, or have the dimensions for the bushing?
  6. Dec 23, 2023 at 1:21 PM
    Watermallon
    Watermallon ID Tacooo
    Zach
    Idaho
    2006 TRD Sport
    My foxes had the same issue but the bushings were rubber, so I shaved some off with a dremel and they slid in just fine.
