Bilstein 5125's w/ Skyjacker 1.5-2" Lift
Discussion in 'Suspension' started by DirtBeers, Feb 7, 2024.
  1. Feb 7, 2024 at 8:40 AM
    DirtBeers
    DirtBeers [OP] Member
    Brandt
    2010 Tacoma TRD OR
    Lifted on Bilstein 5100s with SPC UCA's.
    I have a second gen that is currently lifted. Bilstein 5100's with 2884 coils on front (~1.75") and Skyjacker TCR515S on the rear with a large axle block. The Skyjackers advertise 1.5-2" of lift and the block another 2" maybe. Honestly, I have a hard time believing that it is lifted that much judging by looks. I can post a picture if that helps.
    Long story short, I plan on ditching the rear axle blocks. My question is - with the skyjacker lift only being 1.5-2" and my shocks made for a 2-3.5" lift, will I need to get new shocks or can I stick with what I have? If I stick with what I have, do I need to make any adjustments to bump stops or anything?
  2. Feb 7, 2024 at 10:28 AM
    Mrcooperou812
    Mrcooperou812 Well-Known Member
    Las Vegas NV
    2016 DCSB OR 4WD
    Your bottom shock mounts on the axle will be about 2" closer to the top shock mount on the frame without the 2" block in between the leafs and axle.
    Your 5125 compressed length needs to accommodate this shortened distance. They may still be ok if the rear bump stops are long enough to engage before the rear shocks would top out.
    I am doing the inverse of what you are doing and I am underneath with a tape measure to get actual travel ranges and stops rather than use the lift estimates.
    DirtBeers[OP] likes this.
  3. Feb 7, 2024 at 10:49 AM
    DirtBeers
    Brandt
    2010 Tacoma TRD OR
    That makes a lot of sense. Pardon the ignorance. Is there a video, thread, link you recommend to walk me through how to measure my travel? I am currently undoing all of the crappy modifications the guy before me did. So, I want to make sure I do everything correctly lol
  4. Feb 7, 2024 at 11:56 AM
    Mrcooperou812
    Las Vegas NV
    2016 DCSB OR 4WD
