Bilstein 5160 Question
Discussion in 'Suspension' started by BlancoTaco13, Aug 9, 2021.
  1. Aug 9, 2021 at 9:54 AM
    BlancoTaco13
    BlancoTaco13 [OP] Active Member
    2017 White Tacoma TRD Off Road 4x4
    Is anyone running driver side 5160’s on both driver and passenger sides? As far as I can tell the only difference in the two is the brake line spacer that comes with the passenger side shock.
    a2lowvw likes this.
  2. Aug 9, 2021 at 10:01 AM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    You are correct the only difference is the brake line spacer.
    71tattooguy and BlancoTaco13[OP] like this.
  3. Aug 9, 2021 at 10:36 AM
    BlancoTaco13
    Do you know if there is an alternative to this spacer?
  4. Aug 9, 2021 at 11:42 AM
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    I've seen trucks with a stack of washers, a small piece of aluminum stock and a longer bolt, bending the brake line mount or convincing someone who bought 2 lefts to dig out the spacers and send you one.
    BlancoTaco13[OP] likes this.
