Bilstein 5160
Discussion in 'Suspension' started by Cannonball, Feb 1, 2011.
  1. Oct 20, 2013 at 4:08 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    You could overextend a shock causing it to blow.
  2. Oct 20, 2013 at 8:09 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    I most situations they won't blow.....I had ran them for awhile and was fine just lost the extra droop. In most offroad situations you want as many wheels on the ground as possible so pick a line that allows that if suspension travel is the limiting factor. If your running through whoops at speed and the shock is the limiting factor on droop you'll have issues then. However, you shouldn't be running through whoops beyond your capability anyways!
    In general, you're better off getting a high quality shock like icon, fox or king in the length as close to your travel numbers. I think icon makes the longest 10" travel shock where the bump numbers are still good. Also, DSM sells the "Oakley TRD" 10" travel fox that should work (it's got a custom valved flutter stack too). Was built for an AZ member here!
  3. May 1, 2014 at 9:43 PM
    urban
    urban Well-Known Member
    Illinois/Michigan
    12 DCLB sport OME lift
    305/65r17's on 17x9.5 Rotiforms Cab mount chop 4.10 gears Detroit true track OME 885's Dakars Camburg UCA's Undercover SE Weathertech liners and visors Black headlight mod Debadged Rock Blokz mudflapps (oversized)
    Has anyone tried running 5160 up front??? because they have them for some other trucks fords and they look to have a similar design and mounting types.
  4. May 1, 2014 at 10:19 PM
    95 taco
    95 taco Battle Born
    I don't think the 5160's have spring perch's, on the SA f- series the shock sits inside the coil, but the coil doesn't touch the shock.
  5. May 4, 2014 at 9:00 PM
    monstajp
    monstajp Well-Known Member
    joshua
    las vegas
    2011 trd sport debadged
    Debadged, Blacked Out Taillights and 3rd Brakelight , Blacked Out Grille, Blacked Out Lower Valence, Hot Wheels Badges, Yellow Fog Lights, Rims and Tires. Undercover Swing Case, Pop-A-Lock on my Tailgate, N-FAB Step Bars, Extang Trifecta Bed cover, Aero Cat- Back Exhaust, PIAA Extreme white 4000k Bulbs, Readylift 2.25 Leveling Kit.
    Subscribed
