Bilstein 6112 4 vs 5 setting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by clip, Oct 21, 2021.
  1. Oct 26, 2021 at 5:35 AM
    clip
    clip [OP] Well-Known Member
    VA
    15 OR
    pinstripes. lots of pinstripes.
    I've read through the Bilstein instructions again and am wondering if coil clocking in relation to the top plate really makes a difference. After reassembling on the bench I clocked the top plate with the lower mount but didn't check to make sure the coil was at the same position. Taking it in for an alignment but thinking I'll pull them off again and check everything over since I'm still sitting at 4-5" high after driving a few miles and measuring again. The front is sitting about 1/4" higher than the rear right now and I was looking to maintain factory rake, so I may end up dropping it to setting 2 or 3.
    My guess on that tire size is 265/70/17. I'd like to know what size @Archertl33 has for those KM3s, because they look kind of like 255/85s.
  2. Oct 26, 2021 at 9:27 AM
    N minus 1
    N minus 1 Ruff Road Designs
    San Diego, CA
    2014 TRD Off Road
    255/80r17 Toyo at3 (33.1")
    Boco10[QUOTED] likes this.
  3. Dec 10, 2024 at 1:42 PM
    Coopsdaddy
    Coopsdaddy Well-Known Member
    Quinton
    2012 dclb tacoma
    6112/5160 Deaver stage 1 Are topper Steelies,255/80/17
    Crazy the same lift gives such different amounts of the same vehicle.
    Getting ready to install mine set for 2.2 in lift and 2.5 in rear.
