Bilstein 6112 & 5160 lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Miggyman18, Mar 1, 2020.
  1. Mar 1, 2020 at 7:16 PM
    Miggyman18
    Miggyman18 [OP] Active Member
    Miguel
    18 Tacoma TRD OffRoad DCLB 4X4 White
    So after 2 years of waiting and wife approval. Pulling the trigger on the lift.
    Doing the 6112 & 5160 set-up. Need some simple advise.
    Fronts:
    6112 Bilstein
    Do I need UCA's? Not doing bumper. In the future a 275 / 70 /17 (not E load)
    Rears:
    5160 Bilstein
    AAL: Not doing bumper. Not sure if i need it, But if i need it what are some options? would like to keep the ride smooth.
    Also Doing:
    ARB FK29 Old Man Emu Rear Driveshaft Spacer Kit from Amazon
    Trying to keep it Simple & Clean but specially cheat.
    Thank you Amigos
  2. Mar 1, 2020 at 7:27 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    :popcorn:
    My plan too... just don't know when.
  3. Mar 1, 2020 at 7:30 PM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    I just did a similar "lift" I did half in in the front, I think 3/2. And then the 5160's out back. Rides great.
    Powerprozeus and Superdave1.0 like this.
  4. Mar 1, 2020 at 7:32 PM
    QuicksandTaco
    QuicksandTaco Well-Known Member
    Cody
    Oregon
    2015 Inferno TRD Pro 6spd
    URD short shifter, 285/75/16,
    5160’s don’t lift the rear. Aal is the only way.
    GreyBaldTaco likes this.
  5. Mar 1, 2020 at 7:33 PM
    QuicksandTaco
    Cody
    Oregon
    Aal 3 leaf or single. New leaf pack. Or blocks.
    single leaf I believe gets you a lift but doesn’t add any load capacity
  6. Mar 1, 2020 at 7:33 PM
    50ate
    50ate Well-Known Member
    Washington
    2019 OR DCSB 6spd
    I just did the same on my 19 OR no UCAs set 4/3 (1in) in the front and no lift in the back. 265/70/17 and I love it
  7. Mar 1, 2020 at 7:34 PM
    QuicksandTaco
    Cody
    Oregon
    How high are you lifting? If you go over 2” every one says get UCA’s
    Miggyman18[OP] likes this.
  8. Mar 1, 2020 at 8:21 PM
    Miggyman18
    Miguel
    Was thinking on a 2" on the front and thinking 1" for a complete level. I know for a 1" i have to do AAL
  9. Mar 1, 2020 at 8:23 PM
    Miggyman18
    Miguel
    No rub? any trans vibrations? Drive shaft spacer kit needed?
  10. Mar 1, 2020 at 8:30 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    You may want to consider installing the ECGS bushing as a preventative measure
  11. Mar 1, 2020 at 8:38 PM
    Solislbc
    Solislbc Well-Known Member
    2018 Tacoma TRD Off Road 4x4 6' bed/premium package
    Do these aftermarket kits smooth out the freeway bumps. I feel everything in my off-road in some lanes compared to my wife’s highlander. It’s my daily driver and I want the versatility to be comfortable on my commute to work and off road on weekends.
    TacoZmtn, Tainted and Bradg93 like this.
  12. Mar 1, 2020 at 8:54 PM
    Tainted
    Tainted Well-Known Member
    Same exact boat. Don’t think we can make our Tacoma’s as smooth as a Highlander. I got to drive my coworkers Tacoma yesterday with King suspension and it was still pretty rough but smoother than Bilstein 6112 on roads. I’ve read that Kings shine offroad.
    VLBtaco, TacoZmtn and itz so salty like this.
  13. Mar 1, 2020 at 9:03 PM
    Miggyman18
    Miguel
    is it needed? only doing a 2" in the front. what about 1"?
  14. Mar 1, 2020 at 9:05 PM
    ozpall
    ozpall Well-Known Member
    Oscar
    2017 Taco
    1 sticker
    Today i installed 6112s on the highest setting, front of the truck sits about 1" higher than the rear(all stock in back) , test drove it like that 60mph no vibrations. I ordered a 2" block for the rear.
    YotaFAB likes this.
  15. Mar 1, 2020 at 9:12 PM
    YotaFAB
    YotaFAB Well-Known Member
  16. Mar 1, 2020 at 9:49 PM
    50ate
    Washington
    2019 OR DCSB 6spd
    No problems at all.. manual transmission, I didn’t do anything to the back except change shocks. Aligned fine and drives perfect.
  17. Mar 1, 2020 at 10:39 PM
    Solislbc
    maybe I’ll weight it down with sliders and a rtt to smooth out the ride and save my back.
    TacoZmtn and AKGSD like this.
  18. Mar 1, 2020 at 10:46 PM
    Miggyman18
    Miguel
    trying to ball in budget here man,lol. kings too much $$$
  19. Mar 2, 2020 at 2:51 AM
    GreyBaldTaco
    2019 F150 5.0
    I think 6112's on 3/2 are much smoother than stock on the highway.
    DR TACO and Solislbc like this.
  20. Mar 2, 2020 at 3:57 AM
    wolfman00
    wolfman00 Well-Known Member
    matt
    Gambrills/Crofton MD
    '16 dclb
    sortof stock. 6112/5160, pro wheels and a tune.
    i did 6112/5100 about a week ago- 5/4 and a 3 leaf progressive AAL. no vibes.
    I also have a dclb. you might not need any driveline spacers, i didn’t.
    i had 5100 in the front at 5th clip with a .25” spacer, and 5100 out back with 1” lift blocks. the new suspension is super smooth.
    also- the hype with the 3 leaf AAL is true, it is a massive improvement over a block, also no more axle wrap, very smooth.
