Bilstein 6112 ! Dif drop or not ?
Discussion in 'Suspension' started by lynyrd3, Mar 15, 2017.
  1. Mar 15, 2017 at 3:38 PM
    lynyrd3
    lynyrd3 [OP] STRENGTH DETERMINATION MERCILESS FOREVER
    Bill
    East Central Upstate NY
    Well, just pulled the trigger on 6112 coil overs set at the top notch , 2.5" . Also TC UCAs . Reading so much on to dif drop or not ? Opinions please .
    DrFunker likes this.
  2. Mar 16, 2017 at 10:41 AM
    not0ny
    not0ny Well-Known Member
    2017 MGM TRD SPORT DCSB 4X4
    Bilstein 6112/5160 JBA UCA
  3. Mar 16, 2017 at 2:32 PM
    lynyrd3
    Bill
    Thanks for the response .Think I will skip the dif drop ( even though I'm not off road much at all ) . Maybe go with the Allpro Off-road long travel outer CV boot . Problem is the inner boot tears more often .
  4. Mar 16, 2017 at 2:59 PM
    Crikeymike
    Crikeymike ExitOffroad.com Vendor
    Jax Beach, Florida
    There's some easy checking for you to do. Get all the stuff installed, jack the front end up off the ground with the tires on, then rotate the front tires, one at a time. You'll be able to tell real quickly if there is any binding at full droop. If there is, it's a risk you'll take by not running a diff drop kit. In my 4Runner, I'm using longer travel struts and they were right at the verge of binding the CV's with this same test, so I'm running the diff drop kit now. I'd rather lose an inch of clearance than have to replace the CV's too early.
    But also, if it's a road pounder, and you never reach full droop, then you could skip it too. Just don't jump too many train crossings. hahaa
    lynyrd3[OP], DrFunker and nDub like this.
  5. Mar 16, 2017 at 3:04 PM
    DrFunker
    DrFunker Well-Known Member
    I have 6112 on the 4th notch. No diff drop.
    Where are you? I may be close to you, if you want to see them.
  6. Mar 16, 2017 at 3:04 PM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Now that's some good advice. :thumbsup:
    lynyrd3[OP] likes this.
  7. Mar 16, 2017 at 3:09 PM
    lynyrd3
    Bill
    Not a lot of train tracks around here , Lol . Thanks for the info . Truck has 95000 miles replaced CVs last May because of torn boots , within 2 monthes the inner boot on passenger side tore Have 5100 set at 1.75 right now . But replacing with the 6112 at 2.5 . Just have to wait for the install and see what happens. Thanks
  8. Mar 16, 2017 at 3:09 PM
    lynyrd3
    Bill
    Columbia county , NY
  9. Mar 16, 2017 at 3:10 PM
    Crikeymike
    Jax Beach, Florida
    Yeah, our long travels are about the same extended length as 5100's, so we recommend a DD Kit.
  10. Mar 16, 2017 at 3:10 PM
    DrFunker
    Saw that. :spy:
    I am in the berkshires.
  11. Mar 16, 2017 at 3:13 PM
    lynyrd3
    Bill
    I'm near Catamount ski area .
    DrFunker[QUOTED] likes this.
  12. Mar 16, 2017 at 3:15 PM
    DrFunker
    We are close. I know you have already purchased them, but if you wanted to see them, let me know.
    There are some places down in south county that I like to visit. :D
    lynyrd3[QUOTED][OP] likes this.
  13. Mar 16, 2017 at 3:23 PM
    lynyrd3
    Bill
    What size tires you running ? I'm looking to go bigger than 265/70 16 . So l am also in the market for new wheels .
  14. Mar 16, 2017 at 3:23 PM
    DrFunker
    265/75/16s on Ray10s.
  15. Mar 16, 2017 at 3:37 PM
    lynyrd3
    Bill
    Sounds good .Truck going in for some paint Monday .
  16. Mar 16, 2017 at 3:42 PM
    Plannerman99
    Plannerman99 Well-Known Member
    So Cal
    Our Adventure Vehicle
    I ran a diff drop kit for a while and then yanked it. I did not notice the loss in ground clearance. However, the diff would contact the skid plate when I put the truck in reverse and that irritated the hell out of me. I'm running Icons set at ~2.75" and have no issues with my boots.
    REDdawn6 and lynyrd3[OP] like this.
