Bilstein 6112 Idiocy
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacodad20, Jun 3, 2021.
  1. Jun 3, 2021 at 11:56 AM
    Tacodad20
    Tacodad20 [OP] New Member
    David
    2013 TRD Sport
    Taco sauce sticker, Westin Traxx steps, Westin Bull Bar
    Howdy folks,
    So story is this. During a bout of 3am online shopping while rocking a grumpy baby, I bought some used bilstein 6112 shocks. Just shocks which was fine because I was planning to get some heftier springs for them.
    They came in and I took a quick look at them and didn't see any red flags. I then proceeded to stash them in the garage until I had time to swap them out.
    Got the B12 bilstein springs in and once I had some time I pulled out the struts and had a closer look. That was when I realized I had bought them for the wrong vehicle.
    The return to seller ship has sailed so I am stuck with springs and no shocks. I've done what I can with google but haven't had any luck finding a place that sells just the shock.
    Does anyone out there know of a place that I can source a set? Other than getting lucky with ebay or craigslist.
    Thanks
    For a 2013 TRD Sport.
    llamasmurf likes this.
  2. Jun 3, 2021 at 12:44 PM
    TacoFergie
    TacoFergie Well-Known Member
    Iowa
    What vehicle is it for? 3rd gen, 4runner and FJ 6112's will bolt in. The difference is going to be the clip location on the housing for the height setting. I believe the b12 spring is the same part number across all platforms as well.
    The only way to get a new shock is through Bilstein to my knowledge. But I don't know if they sell them or if it's only based on exchanges.
  3. Jun 3, 2021 at 1:07 PM
    Aardvark13
    Aardvark13 Sultan of Squeeze, Wizzard of Slide
    Byl
    Knoxville
    2014 DCSB OR
    Aardvark4x4 Built for Go
    I ran into this, I have a set of 6112s from a 5th gen 4Runner and the length is correct, but the bottom mount does not fit into the Taco LCA. Fortunately I can use them on my FJ Cruiser.
    TacoFergie likes this.
  4. Jun 3, 2021 at 1:49 PM
    Tacodad20
    David
    2013 TRD Sport
    If I'm honest I dont know, tracking down the part number for just the shock has been problematic, but the lower attachment point for the shock that I bought is 1/2" too wide to fit in my Tacos bracket.
    I got a machinist offering to "modify" it to fit but I'm not comfortable with that.
    Yeah the springs shouldn't be a problem I can just swap them onto the right shocks when I get them.
    A buddy that used to work for O'Reilly is trying to track down a part number. Maybe I will need to be giving Bilstein a shout.
  5. Jun 4, 2021 at 7:44 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Take the next month to build your post count to 50. Don’t pad or shitpost. Just become part of the community. Check out the Code of Conduct for further guidance. Once you have 50, you could post them up here.
    Good Luck.
    wi_taco and crackils like this.
  6. Jun 4, 2021 at 9:01 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    What do they fit ?
  7. Jun 4, 2021 at 9:06 PM
    LNMTacoma2013
    LNMTacoma2013 Well-Known Member
    Louis
    2013 Magnetic Gray TRD
    None Yet
    https://www.bilsteinlifts.com/shop/...tein-6112-series-kit-2005-2015-toyota-tacoma/
    BILSTEIN 6112 .06-2.5″ FRONT SERIES KIT FOR 2005-2015 TOYOTA TACOMA
    SKU: 46-241627
    5 out of 5based on 1customer rating
    (1 customer review)
    [​IMG][​IMG]
    1. [​IMG]
    2. [​IMG]
    3. [​IMG]
    4. [​IMG]
    5. [​IMG]
    $732.00
    18 left in stock
  8. Jun 4, 2021 at 11:31 PM
    Tacodad20
    David
    2013 TRD Sport
    I'm not sure what they do fit. I can post the part number later. They are sitting under my desk at work.
    Thanks for the leg work LMNT, but I am actually trying to get just the shock part of the kit. Not the whole assembly. I may have to bite the bullet and do that, but would like to avoid it seeing as I already have the B12 bigger springs.
  9. Apr 14, 2022 at 12:33 AM
    TacoTuesday1
    FL
    with the eternal Bilstein out of stock on 6112,
    has anyone taken to trying to fit 5th gen t4r TRD PRO ones?
    I see them for sale used pretty regularly
