Bilstein 6112- Need Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GrayMetalic 2015, Jul 21, 2017.
  1. Jul 21, 2017 at 12:48 PM
    #41
    DrFunker
    DrFunker Well-Known Member
    Did you have to add the relocate kit?
  2. Jul 21, 2017 at 12:49 PM
    #42
    DrFunker
    I can go at a good clip. Where I notice the 6112s really shine is on rough/washboard dirt roads. The truck does not chatter or move around at all.
  3. Jul 21, 2017 at 12:50 PM
    #43
    DrFunker
    I have a 3/8" in my driver side.
  4. Jul 21, 2017 at 12:50 PM
    #44
    DrFunker
    @tacobell007 If you have a chance, look through this and see if there is anything going on here. Thanks.
  5. Jul 21, 2017 at 1:20 PM
    #45
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    I have my 6112s set on the 4th notch but I'm in a 3rd gen and they require more pre load to get lift. I've always heard the 3rd notch is ideal for 2nd gens. Surprised to see your getting 3.5" What's the part number on those 6112s. Are you sure you got the right one for the 2nd gens and not the one designed for 3rd gens. They supposedly are different.
    DrFunker likes this.
  6. Jul 21, 2017 at 1:30 PM
    #46
    GrayMetalic 2015
    GrayMetalic 2015 [OP] Well-Known Member
    2015 Tacoma TRD Sport
    Bilstein 6112 4th notch Bilstein 5100 rears 1.25" rear block Light Racing UCA BFG KO2 265/70/17 on Fuel 17x9
    Under 10 mph anything over that the passenger side tops out
  7. Jul 21, 2017 at 1:37 PM
    #47
    GrayMetalic 2015
    Vanga STL thank you for your reply
    Kit # 46-241627
    Number on shock- 24-241618
  8. Jul 21, 2017 at 1:44 PM
    #48
    GrayMetalic 2015
    Don't know that the relocate kit is?
  9. Jul 21, 2017 at 3:01 PM
    #49
    DrFunker
    Sway bar relocate kit.
  10. Jul 21, 2017 at 4:49 PM
    #50
    GrayMetalic 2015
    Ok I will look into that but so far not an issue
  11. Jul 21, 2017 at 5:17 PM
    #51
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    I think it's too high of a height. Maybe take them down to 3" and try that setting in the same speed bump which is causing the harshness? Just because the 6112 has all those snap ring slots doesn't mean they are intended to be used. The 6112 is a bit of a universal design...they just tuned the valving for the Tacoma.
  12. Jul 21, 2017 at 5:58 PM
    #52
    GrayMetalic 2015
    mbrogz3000- thank you for the reply
    I will probably need to lower to maybe even the 2nd notch because I'm just getting substantial more lift than what is published. Financially it's about $450 to take it down a notch or two, $150.00 each shock to remove and re-seat the clip and then $120 for an alignment. Not to mention if I go straight to 2 notches I'm always going to wonder if the 3rd notch would work.
    I guess if I can get feedback comparing the following I could make a decision:
    On a scale of 1 to 10
    5100 with OME coils with perch set at the 2nd notch versus 6112 with OEM coils with perch set at the 4th notch
  13. Jul 21, 2017 at 9:17 PM
    #53
    Sna
    Sna Well-Known Member
    Alberta
    ‘15 trd sport 6MT dcsb, mostly stock?
    Looks just like my left side with 1/4" spacer.
  14. Jul 21, 2017 at 9:20 PM
    #54
    Sna
    Alberta
    If you can tear the assemblies out yourself and find a shop with a wall mounted spring compressor it will significantly cut down on the cost. I did this (everything stayed together and they compressed the spring enough for me to move the clip down) and the shop only charged me for the labour (which was .3/hr) and then I came back for a new wheel alignment once I put everything back in.
    PzTank likes this.
  15. Jul 21, 2017 at 9:20 PM
    #55
    GrayMetalic 2015
    Sna- thank you for your reply and I'm glad that my 1/4" spacer is like yours,
    Can check that off the list.
  16. Jul 21, 2017 at 9:25 PM
    #56
    Sna
    Alberta
    Are you 4x4? I don't see any front driveshafts in those pictures? If not, then that's probably your height issue.
  17. Jul 21, 2017 at 9:27 PM
    #57
    GrayMetalic 2015
    I changed my air pressure, the shop that installed the tires and rims inflated them to 45 psi, I decreased them to 39 all four to start with. Truck seemed to drive better in the highway.
    Leaving work there are about 7 speed bumps, the first few i went over at about 10 mph and passenger side topped out. On the last couple I went about 15 mph and it actually was better. Tomorrow morning I will try going faster and see if that's how I need to go over speed bumps either very fast or very slow.
  18. Jul 21, 2017 at 9:31 PM
    #58
    GrayMetalic 2015
    I'm not 4x4
    Sna likes this.
  19. Jul 21, 2017 at 9:36 PM
    #59
    Sna
    Alberta
    39 still seems high...(stock tires?)
    That will be your problem then....notch 2 or 3 would be better, but given the height you're at on the 4th notch, I would go to notch 2.
  20. Jul 21, 2017 at 9:46 PM
    #60
    GrayMetalic 2015
    I'm running 265/70/17 BFG KO2
    I appreciate the feedback and going to the 2 notch does seem resonable. What do you think the lift will be, 2"
    Tacomamike mike likes this.
