Bilstein 6112 Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by IrishRed, Mar 16, 2020.
  1. Mar 16, 2020 at 6:02 PM
    IrishRed
    IrishRed [OP] Appalachian Ridgerunner
    Central PA
    2017 TRDOR DCSB 4x4 MGM Prem&Tech Auto
    Eibach Suspension, JBA UCA’s, 16” SCS Ray 10s, BFG KO2s, ECGS Bushing, Pro Skid Plate, Fumoto Valve, Pro Grille, Opt7 Tailgate Light Bar, AVS Window In-Channel Vents, Roknlokz XL Mud Flaps, Husky Floor Mats, Bed Mat, Tailgate & Glovebox Letter Inserts, TRD Grille Badge, Exhaust Tip, Toyota Hitch Plug.
    Hi, folks. Just when I thought my mind was made up about going with 887 coils and NitroCharger (soft valved)shocks, this Bilstein setup has caught my eye.
    I have a quick question. I’d like to achieve 2” of lift on my ‘17 Off-Road, but it looks like that is maxing these out. Would the ride be very stiff because of the pre-load??? Are you guys satisfied with the ride quality.
  2. Mar 16, 2020 at 6:26 PM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    I love the ride quality of the 6112/5160 combo, I only have mine set to a half inch lift though.
    Tainted likes this.
  3. Mar 16, 2020 at 6:59 PM
    4_low
    4_low Member
    2017 Tacoma DCSB TRD OffRoad 4x4
    Mine are set at 6/5 and ride better than anticipated. To me they ride great, a little stiffer than stock but in a good way as stock was too soft(TRD Off Road)
    tacothyme and GreyBaldTaco like this.
  4. Mar 16, 2020 at 7:03 PM
    gunn_runner
    gunn_runner www.gunnphotoservices.com
    Rocky River, OH
    2013 DCLB TRD
    OME 886 & Dakars. 35" Mickey Thompson Baja Boss
    Having gone from OME 886 to 6112, the difference is night and day. The larger bore is so much smoother IMO
    marinemonkey and GreyBaldTaco like this.
  5. Mar 16, 2020 at 7:04 PM
    ghost_ix
    ghost_ix Member
    Bay Area, CA
    2019 TRD Off Road
    What clip setting are you on?
  6. Mar 16, 2020 at 7:05 PM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Mine are set on the 4th notch. Definitely stiff. But not unbearable. You could also get a 650 pound spring and set it at a lower notch to achieve the same height.
    crashngiggles likes this.
  7. Mar 16, 2020 at 7:05 PM
    TK11
    TK11 Well-Known Member
    Tom
    N. CA
    2019 TRD OR MT
    Bilstein 6112 / 5160, 275/70/17 BFG KO2, Caliraised Sliders, SSO bumper, Warn winch
    Riding at max height and the ride is not stiff to me.
  8. Mar 16, 2020 at 7:05 PM
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Large bore o_O, gettin kinda hot in here
    Tainted and GreyBaldTaco like this.
  9. Mar 16, 2020 at 7:45 PM
    gunn_runner
    Rocky River, OH
    2013 DCLB TRD
    only for you, my man...
    NYCTaco52[QUOTED] likes this.
  10. Mar 16, 2020 at 8:26 PM
    PinStripes
    PinStripes Well-Known Member
    Oregon
    2018 Cement OR DCLB
    Someone get that man a remote reservoir.
  11. Mar 17, 2020 at 5:23 AM
    IrishRed
    Central PA
    Thanks, for all the responses. I will definitely do some more homework. I just don’t know if I want to go with a setup that relies on preloading coils that much to achieve the amount of lift I’m seeking. I fear having an unforgiving & harsh ride.
    That is why I find the 887 coils appealing. They’ll give me the amount of lift I’m after because of their length and not from pre-loading them.
    I’m also a bit hesitant to go with the Bilsteins because I have some doubts as to how well they’ll hold up to the Pennsylvania winters and the corrosive crap they treat the roads with around here. I’ve seen some pictures of them being used in harsh environments and they didn’t fare too well. I had Ranchos on an F150 that had the same “natural finish” as the Bilsteins and they looked terrible after just one year.
  12. Mar 17, 2020 at 6:25 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    You thought of clear coating them with a good urethane clear coat?Before Install
  13. Mar 17, 2020 at 6:29 AM
    Navigator1
    Navigator1 Assistant to the Regional Manager
    Spokane WA
    18 TRDORDCLBCEMENT
    I’m running with 1/2” top plate spacers and I think I’m on clips 3/4(maybe 4/5). Rides fantastic. About 2.25” of lift.
  14. Mar 17, 2020 at 6:57 AM
    ghost_ix
    ghost_ix Member
    Bay Area, CA
    2019 TRD Off Road
    Did you see the difference more off road or on road? Or both?
  15. Mar 17, 2020 at 7:08 AM
    GreyBaldTaco
    2019 F150 5.0
    Both
  16. Mar 17, 2020 at 7:27 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    See my signature...
  17. Mar 17, 2020 at 8:31 AM
    B619
    B619 Well-Known Member
    2020 DCSB OR Premium VooDoo Blue Tacoma
    Don't mean to thread jack but I don't want to create and flood the forums.I just wanted to know what else is needed for the 6112 F and 5160 R? Add A leafs, Upper Control Arms, am I missing anything else? I am just trying to prevent rubbing on my wheel and tire set up of 17x8.5 -20 265/70/17.
  18. Mar 17, 2020 at 8:52 AM
    TK11
    Tom
    N. CA
    2019 TRD OR MT
    I did add-a-leaf in the rear because I run the 6112's at max height. They are cheap and very effective at adding some height and preventing the bed from sagging under load. See my pic to left. I also added adjustable upper control arms. That's optional but at max height allows adjustment for correct alignment (esp. camber, I believe).
  19. Mar 17, 2020 at 9:04 AM
    09TRDSport4x4
    09TRDSport4x4 OCD Approved!
    Nick
    Southwest Ohio
    I know this is a third gen thread but let me add some insight based on my experience...
    One, Bilstein shocks use digressive valving, and thus, excessive preload or not, will always feel “stiffer” than shocks valved more linear or progressive, especially at low speeds. However, with that said, the digressive valving is better for handling and “body roll” so some people prefer this trade off.
    Two, I can personally attest to the Bilstein finish holding up like utter garbage to Midwest winters. I have a set of 5100s on my truck now that have been through four winters in southwest Ohio and let’s just say, they don’t look pretty.
    Three, I’m in the market for a suspension upgrade for my 2nd gen and have been going back and forth between a 6112/5160 setup or a Fox 2.5 setup. Both have their pros and cons, but I’m leaning Fox right now for the adjustability and linear/progressive valving.
    After being beat to death by 5100s on these terrible roads, I’m hesitant to believe that the larger diameter 6112 will handle that much differently, especially with the amount of preload I’d need to get 2.5” or more of lift. I’ve had a 1/2” top plate spacer on the driver’s side and a 1/4” on the passenger side (on top of my 885s) for almost a year now and I think I’m ready to move away from the ride quality that comes with it. The front of my truck does not handle washboard roads or harsh bumps at low speed well at all. And while people claim the 6112s soak up these bumps with ease, I don’t know if I can pull the trigger on another set of Bilsteins. The price difference is very appealing though...
    teber71, AKGSD and IrishRed[OP] like this.
  20. Mar 17, 2020 at 9:21 AM
    IrishRed
    Central PA
    Thank you, for this honest assessment. You have confirmed a few of my concerns regarding this setup.
    I’m still leaning towards the OME 887 w/ NitroCharger (soft valved) for my lift. I tend to like a softer ride and when I spoke to Marie at Headstrong, she indicated that, in her experience, the NitroCharger shock would provide a softer ride over the 5100 Bilsteins when paired with the 887 coils.
    I’m about to pull the trigger and find out, but I wanted to investigate the Bilstein 6112 option a bit more before I made a final decision. The fact that the Bilsteins have trouble standing up to harsh winter environments is a major turnoff to me.
