Bilstein 6112 vs 5100 to fit 33's with negative offset
Discussion in 'Suspension' started by lilsmallz77, May 18, 2023.
  1. May 18, 2023 at 8:44 PM
    lilsmallz77
    lilsmallz77 [OP] Member
    I want to lift my truck 3" Im debating between 5100 and 6112. I was planning on going with the 6112 because of the off road capability but I believe they arn't a true 3 inches. I believe my only option to get a true 3" with the Bilstein 6112 is put a half inch spacer. not sure how that would ride and the point of me buying new coil overs is so I can avoid a spacer lift. For the 5100 without maxing out on the adjustable coil over settings which Im sure it would ride rough on a higher collar setting, I need a pre loaded collar. I know Wescoat designs make one. So just seeing my options here. Anyone with advice or similar setup please let me know
  2. May 18, 2023 at 11:59 PM
    Sig Taco
    Sig Taco Well-Known Member
    2021 Taco DCSB
    Icon Rebounds 17x8.5 Toyo 35/12.5/17 JBA UCA, Bilstein 6112/5160, KDMax
    I have a .25" top plate on the old model 6112(with 6 perches). Have it on 6/5 riding on 285/75/17s. Rides good IMO. I'm guessing my lift is @3.25". 40.5" ground to fender.
    In a few weeks I'm switching to a .5" top plate.
    You could probably do 2" lift on the 6112 and .5" plate for a true 3" lift. Would ride great! Might have to think about UCAs.
  3. May 19, 2023 at 7:35 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    Fox and Locked suspension 63's Skinny 33's
    Look up tinkerers adventure on youtube. Fitting any tire size has nothing to do with ride height, it is determined by wheel specs, tire width, alignment, bumpstop spacers, and your favorite cutting tool.
    findingthingsout likes this.
  4. May 19, 2023 at 7:37 AM
    TacoBuffet
    TacoBuffet Well-Known Member
    AL
    Taco #13, 2022 OR DCSB Cemint
    5100s, TE37s, Toyo RTs, Tint, Bedmat, LEDs
    5100s top perch and 1” block running 285/70r17 -12 no issues
  5. May 19, 2023 at 8:36 AM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    This.
    Also, 6112 ALL DAY over the 5100.
  6. May 19, 2023 at 10:01 AM
    Steadfast Rocky
    Steadfast Rocky Well-Known Member
    Rocky
    2012 DCSB TRD BAJA
    And for the love of good do not put any of these on the top perch setting if you plan to use the truck offroad, your down travel will be no existent.
