Bilstein 6112 w/'Aftermarket' Springs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jasonl275, Jul 22, 2019.
  1. Jul 22, 2019 at 10:00 PM
    jasonl275
    jasonl275 [OP] Active Member
    '11 DCSB TRD OR 4X4 6MT
    I'm running 6112's with the Bilstein (600lb I think) Springs set at the 3rd notch. Got an ARB bumper on the way (+~100lbs).
    I am a little puzzled as to which springs to get to compensate for the extra weight.
    I know I'll need 2.5" springs to fit the circumference of the bilstein shock body.
    What spring rate would you suggest?
  2. Jul 23, 2019 at 6:40 AM
    MYKOSPRO
    MYKOSPRO Well-Known Member
    Houston, Tx
    15’ TRD Pro
    The Bilstein 650# spring should be enough to keep the same ride height. If you want to get other brands I believe it would just need to be 14" x 3". The inner will be 2.5"
    07tacomatoy likes this.
  3. Jul 24, 2019 at 6:15 PM
    Ten Rounder
    Ten Rounder Old Man and his Dog
    Southwest Montana
    20 TRD Offroad, 19 4Runner Premium SR5
    Heated seats, It's Montana
    If you are V6 you might need #700. With a 4 cylinder with Iron I'm on the stock #600 and that's even with a winch
  4. Jul 24, 2019 at 9:40 PM
    dfulks
    dfulks Well-Known Member
    Dillon
    Portland
    2012 TRD Off Road DCSB
    I run the bilstein 6112's with an ARB, no winch and on the 2nd setting. Barely any rake, almost dead level. 3rd notch would put me nose high with stock rear springs. The bilsteins are 600lb coils, stock is 540 i believe. Eibach makes a 620lb spring that'd be perfect.
