Bilstein 6112s
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Feranx, May 22, 2024.
  1. May 22, 2024 at 7:50 PM
    Feranx
    Feranx [OP] Member
    2021 Barcelona Red Tacoma TRD Sport
    S&B cold air intake Borla S Type CatBack Exhaust KSP 1.50 inch Hub-centric pro billet wheel spacers Bilstein 6112 coil-overs with .50 inch spacer Bilstein B8 tubular ball joint upper control arms Bilstein 5125s rear shocks with extended travel 2 inch rear blocks
    heard a loud metal sound coming from front suspension, after inspecting found that the nut on one of the struts seemed to be treaded all the way but the washer was loose and moves up and down freely. Any ideas of what might have cause this and how to fix it?
  2. May 22, 2024 at 11:11 PM
    girMobi
    girMobi Well-Known Member
    2020 TRD OFF
    RCI, Martin, Vort and Irken tech
    you talking about the 3 nuts on the hat top or the center one? tighten them back down and keep going.
    Suspension bolts can loosen up, you are supposed to inspect them 100 or so miles after install and at an interval that works for you, check them every oil change for instance.
  3. May 23, 2024 at 12:07 AM
    Feranx
    Feranx [OP] Member
    The center one with the washer, im going to try that tomorrow, thanks.
  4. May 23, 2024 at 1:36 AM
    girMobi
    2020 TRD OFF
    check the cir-clip at the lower end of the shock and the perch where the base of the coil sits. It should sit flat and even in one of those grooves.
    Yeah, the center bolt is usually under a lot of tension, was this a recent install?
  5. May 23, 2024 at 2:15 PM
    Feranx
    Feranx [OP] Member
    Yes it was recently installed, I noticed today they forgot to add the lower washer on the strut.
