Bilstein 8112. What do you run for the rears?
Discussion in 'Suspension' started by hr206, May 16, 2024.
  1. May 16, 2024 at 9:56 AM
    hr206
    hr206 [OP] Well-Known Member
    Western Washington
    '16 DCSB TRD OR, '98 regular cab 4x4
    I'm contemplating the basic Zone Control 8112's for the front. Saw they have 3 options for the rear in order of increasing cost:
    1. Smooth body 8100's ~$600
    2. 8100's with DSA+, sort of like Fox DSC's with high and low speed adjustments ~$750
    3. 8100's with external bypass ~$1100
    I'm thinking the external bypass to somewhat match the capabilities of the front. Or the DSA version since I occasionally tow and would like to firm up the rear.
    What are you running and why did you go that way?
  2. May 16, 2024 at 10:47 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    Id call Ian at wheel every weekend. He seems to be the most knowledgeable person with Bilstein shocks.
    https://www.wheeleveryweekend.com/
    Id guess he would have you shy away from external bypasses but give him a call
    hr206[QUOTED][OP] likes this.
  3. May 16, 2024 at 7:35 PM
    eurowner
    eurowner Duke Sky
    Scoty
    I went with the matching external bypasses.
  4. May 16, 2024 at 10:37 PM
    hr206
    Western Washington
    How do you like them? Do the adjustment knobs make a noticable difference?
  5. May 17, 2024 at 8:08 AM
    eurowner
    eurowner Duke Sky
    Scoty
    TBH, I have not had to adjust compression or rebound from the factory settings fully empty, loaded or towing my Jayco Baja 10y popup.
