Bilstein Adjustable lift kit with 5100 shocks
Discussion in 'Suspension' started by jordando89, Jan 19, 2012.
  1. Jan 19, 2012 at 12:26 AM
    jordando89
    jordando89 [OP] Well-Known Member
    jordan
    idaho
    2008 white double cab long bed sport 4x4
    3in lift painted sport wheels
  2. Jan 19, 2012 at 12:36 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Looks like all the bells & whistles, except didnt see extended brakelines..
    maybe im missing something, good price...;)
  3. Jan 19, 2012 at 12:54 AM
    jordando89
    jordan
    idaho
    so i will need extended break lines? anyone know where to get them?
  4. Jan 19, 2012 at 1:40 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    You shouldn't need extended brake lines with that set-up. What's up with the back order? There's another kit for $800 already assembled front shocks. Just remove the others and replace. You "may" need UCA's or decide to get some down the road if you get alignment issues!
    Also, the front diff drop will do nothing........you could always piece together your own kit. All you'll need are front coilovers (shocks and springs), rear AAL with longer ubolts and rear shocks!
  5. Jan 19, 2012 at 4:15 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    You may or may not need extended lines, I've lifted some '05-'06's & not needed them (simple AAL, only an inch or 2, & i've done the same thing to some newer 2nd gens. '09- '11 & the lines have almost no slack, seems to matter where they;re made,
    I've had great success with diff. drops in situations where just a little change in front diff. height corrects CV angle, which if too much causes pre mature wear & tear on the CV shafts but REALLY shortens life of CV boots
  6. Jan 19, 2012 at 4:23 AM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner
    Stuff
    What seething you going to put it at OP?
    If you do .85 you will not need UCAs.
    1.75 you don't need to but you will have lil caster.
    2.5 still don't need to but you will have no caster so it's highly recommended.
    Break lines you should not need. I lifted my rear up an inch and I am okay.
    Also the more you lift the front end since you 4X4 the more strain you will put on your cv joints.
  7. Jan 19, 2012 at 4:26 AM
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
  8. Jan 19, 2012 at 5:33 PM
    jordando89
    jordan
    idaho
    is there any other problems with lifting?
  9. Jan 29, 2012 at 1:53 PM
    jordando89
    jordan
    idaho
    which one should i get and why?
    ----OME3-05-AL----
    Included in kit:
    FRONT: (2) OME 884 standard/light load front lift coil
    oyTec Top plate spacers for a full 3" front lift & (6) top plate studs
    REAR Options:
    2" ToyTec Standard Add-a-leafs (long add-a-leaf for the best ride), w/OEM style anti-friction Pads, & new leaf spring center pins
    OR
    *BK0510***
    1.5 to 3" lift kit with Eibach front coils (3" average lift is achieved with coils and setting the shock adjustment on the second C clip setting from the bottom) DO NOT EXCEED THIS SETTING OR DAMAGE CAN OCCUR
    Double cab models may require top plate spacers for full 3" lift
    Includes:
    C475 Height adjustable Bilstein front 5100 shocks
    TP14 spacer for correction of drivers side lean
    112-620 Eibach/Toytec front coil springs 620lb spring rate
    TAC-DR-05 Front diff drop kit (choose from options)
    Rear Options: Choose below
    TAC-AL Toytec standard 2" lift add-a-leafs with anti friction pads
    TAC-AL-TSB Toytec TSB 1.5" add-a-leafs for use with 4 leaf rear springs
    1 1/2" blocks with U-bolts
    1" blocks with U-bolts
    C476 rear Bilstein 5100 shocks
  10. Jan 29, 2012 at 2:12 PM
    jordando89
    jordan
    idaho
  11. Aug 1, 2012 at 9:59 PM
    Charlie10
    Charlie10 New Member
    2003 Tacoma Double Cab 4x4
    Hey guys, i'm wanting to install the ultimate lift kit to my '03 Tacoma Double Cab 4x4 and I have a couple questions. The ultimate lift kit can be set from 0"-3 1/2". If I set the coilovers at 3 1/2", will I need the 3/4" top plate spacers? And if so, can the 1/4" spacer used to correct driver's side lean be used with the top plate spacers? Any help will be greatly appreciated! Thanks!!!
  12. Aug 29, 2013 at 3:02 PM
    lightinglark956
    lightinglark956 Well-Known Member
    pat
    springfield il
    2012 tacoma trd offroad
    k&n cai ,flowmaster series 40 single in dual out with custom dual exhaust out the back with 4 in ss cans ,backflip vp tonneau Blackhorse stainless bulbar ,35% tint front and rear,rainguards ,glovebox console organizer,ome 887's ,Dakar rear leaf package ,ome nitro charger schocks ,lr uca's ,diaz devil horn emblem,goodrich ext brake lines
    hey guys I just want to level my 2012 dbl cab short bed 4x4 trd off road can I just put all 4 5100's and adjust the fronts to .85 or 1.75 ? would I need to realign the front end ? kinda went over budget on the kn 63 series cai and custom dual exhaust out the back ? any suggestions don't do much off road but looking for level better riding thanks
